Commission Settings & Calculation Issue
Viewing 17 reply threads
    • #191314
      Chris
      Hi support,
      The commission seems not working around with my settings. My settings are:
      1) I’ve set the global commission in mvx settings as shown in
      https://prnt.sc/VBOX7CznvnMQ
    • #191315
      Chris
      2) I’ve set the category-wise commission in products > categories > edit category as shown in
      https://prnt.sc/Mfcny3DkM1Xg
    • #191317
      Chris
      3) Product-wise commission is unset at 0 as shown in
      https://prnt.sc/QJZrC3ideyIR
    • #191318
      Chris
      Vendor-wise commission is unset at 0.00 as shown in
      https://prnt.sc/O00y1rGPUaJT
    • #191319
      Chris
      The product costs $1500, with the settings set above, it should be calculated by using the category-wise commission, which supposedly should result in $752 [($1500 x 50% = $750) + $2]. However, it was showing $1485 instead.
      1) The commission amount shown on admin end are $1489, as shown in
      https://prnt.sc/miI30sMpRdi4
    • #191321
      Chris
      2) The commission amount shown on vendor’s end are $1489, as shown in
      a) https://prnt.sc/Gs7nLQ46zPJv
    • #191322
      Chris
      b) https://prnt.sc/TVEEz9PaHBpJ (another view)
      Am I missing anything or? Please guide me accordingly…
      Thank you
    • #191334
      Hi @Chris
      I have set all the commission as per your setting on my end . Kindly check the screenshots –
      global commission- https://prnt.sc/9hnDE4OlXy_e
      Category wise – https://prnt.sc/LkyKUF7dXdkY
      Vendor commission – https://prnt.sc/a8CWkodykH8O
      Product wise – https://prnt.sc/M6-OnqxxvFcc
      Now this is the screenshot of the commission generated – https://prnt.sc/DbdUDRCJkasI
      As per the commission hierarchy of MultiVendorX if you set product wise commission that will override all other categories . But now in this case as product wise commission is not set hence category wise commission will get the priority and commission generated will be calculated based on that .
      As you can see the flow is working fine on our end there might be some with your settings . Kindly check that carefully . If you still face issue please create a staging site and share the site url , admin access with us so that we can help you accordingly .
    • #191316
      Chris
      3) Product-wise commission is unset at 0 whereas Vendor-wise commission is unset at 0.00 as shown in
      Product: https://prnt.sc/QJZrC3ideyIR
      Vendor: https://prnt.sc/O00y1rGPUaJT
    • #191320
      Chris
      Thank you
    • #191421
      Chris
      I’m still facing this issue on commission. I can’t create a staging site right now as my hosting provider doesn’t have this feature yet, but it looks like they will be rolling out the staging features next week. Is there any other way for you guys to help me accordingly? Else, sadly I might need to wait until next week.
    • #191448
      As this is a commission-related issue, can you share the temporary admin access to your site? We will just place a demo order and recheck all the settings.
      While sharing the access, don’t forget to mark the response as private.
    • #191450
      Chris
    • #191471
      Hi @Chris
      We have created a test vendor and test product on your site and tested the flow on your end and it is working fine . Kindly check the video https://watch.screencastify.com/v/8OrE4aPY2Bh7Vb1ItKwL
      The commission is getting calculated on the 50% commission set for the category .As category wise commission will be prioritized between global commission and category wise commission
      Can you please check the settings again?
    • #191527
      Chris
      I’ve checked the settings again and placed quite a few test orders but it all failed until I tried to observe the difference between the vendors. The test vendor that you guys created doesn’t assign to a membership plan whereas the vendor that I’m testing is assigned to a membership plan, and I think I’ve found the cause of this issue, hopefully. The culprit is the commission settings in the marketplace membership. The commission type in the marketplace membership (products in mvx subscription) must be chosen and the amount I left it empty (not sure if admin must set it or not). Once set, the commission is following the category levels rules for overriding.
    • #191542
      Hi @Chris
      The admin must set commission for their vendors in their membership package https://prnt.sc/FQSnzwkx4yKs . Once a vendor comes under a membership package then the commission for those vendors will get calculated on the commission set by the admin in the membership package .
    • #191546
      Chris
      Alright, I think its solved for now. You may close the thread now. Thanks.
    • #191553
      Thanks for the update . If you face any issue or need help in future please open a new thread .
      Great news! Joining the MultiVendorX community on Facebook (https://www.facebook.com/groups/226246620006065) is a great way to stay up-to-date with the latest updates and get tips from other users. Look forward to connecting with like-minded people and learning more about MultiVendorX
  • The topic ‘Commission Settings & Calculation Issue’ is closed to new replies.
