Hi Klaus Thomas Russ, In order to hide this features from vendor dashboard, you can add this code in functions.php of your child theme :
add_filter( 'mvx_before_dashboard_widget', 'new_before_mvx_dashboard_widget', 10, 1 );
function new_before_mvx_dashboard_widget( $vendor_dashboard_widget ) {
unset($vendor_dashboard_widget['side']['mvx_vendor_product_stats']); //remove Product Stats widget
unset($vendor_dashboard_widget['full']['mvx_vendor_stats_reports']); //remove Stats report widget
unset($vendor_dashboard_widget['normal']['mvx_vendor_visitors_map']); //remove visitors map
return $vendor_dashboard_widget;
Copy
Let us know if you have any further query.
