November 30, 2022 at 10:24 PM #147063l.ganParticipant
I just now noticed that if I, the administrator, add a variable product – different sizes (For example: Pants – M and L) and assign a vendor to it – the product appears in the vendor dashboard.
But if the vendor opens this product and resaves it – it becomes simple! And variations flies as well as the choice of size.
How to avoid it? Turns out it’s a common thing…
Does the free version not support variable products at all, even if the administrator added them? -
December 1, 2022 at 1:30 AM #147109l.ganParticipant
Maybe I didn’t fully explain:
I give the opportunity to edit the product fields – change the article, enter the dimensions of the product, add a note to the product. And if any of this changes for a variable product (i.e. the vendor presses the “update product” button), the product becomes a simple product! And then it is impossible to return everything back without the help of the administrator.
Is there a way to leave “variable product” as “variable”?
not change it to “simple” when updating meta fields in the vendor dashboard? -
December 1, 2022 at 2:24 PM #147203Sangita Support SquadKeymaster
To add a Variable Product you will need the pro version of our plugin. So make sure you have the pro version of the plugin and you have enabled the variable product from Marketplace types module : https://prnt.sc/UF9rvPiN7-V3
we have checked the flow shared by you on our end but the variable product remains variable in vendor dashboard too even after changing/adding attributes .https://watch.screencastify.com/v/3ajj6hihwC3KlvJI4XBT -
December 1, 2022 at 5:16 PM #147221l.ganParticipant
Hello
I know. about the pro version.
But I’m using the free version. And in the free version – if you add a variable product from the admin panel, then in the vendor dashboard – it will be opened as “simple” and will be saved as simple.
You show me a demo of your professional version, and I tell you about the free version. Check it out on free version – variable product added from admin panel – saved in dashboard as simple
December 2, 2022 at 1:27 AM #147248NerdySupportExpert MoumitaKeymaster
@l.gan, if the vendor doesn’t have any variable product add option, then I am afraid they can’t also edit this.
Only admin can edit them.
February 9, 2023 at 2:57 PM #180107WCMp AdminKeymaster
We haven’t heard back from you, so we presume this issue has been fixed.
So we are closing this one.
If you need any further help, do open another thread.
The topic ‘Question-problem with variable products of the free version’ is closed to new replies.
