- This topic has 55 replies, 2 voices, and was last updated 1 year, 4 months ago by
September 25, 2024 at 1:17 PM #235686
olan
ParticipantThe enquiry form is showing title and close and save buttons. Field for enter credentials are missing.
September 25, 2024 at 1:22 PM #235690
KeymasterHello @olan,
We’re sorry to hear about the issue you’ve encountered.
Please navigate to your admin dashboard and go to CatalogX > Settings > Enquiry Forms. Under the ‘Enquiry Form Field’ section, ensure that the necessary field sections are enabled as needed (https://prnt.sc/1AJ2MAoQBo3p). Then check the enquiry form again.
If you have any further questions, feel free to let us know.
September 25, 2024 at 1:48 PM #235694
olan
ParticipantI’ve navigated to the dashboard, but I see only the catalog (without the x) menu option.
See attachement
In thats screen I can’t change anything.
September 25, 2024 at 2:38 PM #235696
KeymasterHi @olan, Sorry to hear you’re facing this issue.
It seems there might be a theme or plugin conflict. To troubleshoot, please deactivate all plugins except WooCommerce and CatalogX, and switch to a default theme like Twenty Twenty-Four or Storefront to see if the issue persists.
If the problem continues, kindly create a staging site that replicates your live site where the issue occurs, and share the staging URL along with temporary admin and FTP access. This will allow us to investigate the issue on your end.
Please remember to mark your reply as private when sharing the access details.
October 7, 2024 at 5:02 PM #235973
olan
October 7, 2024 at 5:27 PM #235976
Keymaster@olan, Please create a staging site that is an exact replica of your live site. Share the staging site URL, along with temporary admin and FTP access, so we can investigate the issue and assist you further.
October 7, 2024 at 6:54 PM #235978
olan
October 7, 2024 at 8:59 PM #235985
KeymasterYou can simply use the WP Staging plugin on your end to create a staging site.
If you need any further assistance please do let us know.
October 8, 2024 at 1:50 PM #235998
olan
October 8, 2024 at 2:49 PM #236001
KeymasterHello There, Thanks for sharing the access. But unfortunately we are not able to access your staging site from the link you have shared. We are getting this page https://prnt.sc/KLUw6n1cXhZb.
So kindly check and share the correct staging site access with us so that we can look into your issue to assist you further accordingly.
October 8, 2024 at 2:59 PM #236002
olan
October 8, 2024 at 3:27 PM #236004
Keymaster@olan, We are still getting the same.
October 8, 2024 at 7:08 PM #236020
olan
October 8, 2024 at 9:03 PM #236023
October 9, 2024 at 11:52 AM #236029
olan
October 9, 2024 at 7:39 PM #236034
olan
October 10, 2024 at 9:08 AM #236043
October 14, 2024 at 1:39 PM #236107
olan
ParticipantYour IP is whitelisted, can you confirm?
October 14, 2024 at 1:45 PM #236108
KeymasterWe are still not able to access your site. Getting this https://prnt.sc/tdC7WYKxnF8D while clicking on the link shared by you. Kindly whitelist this ip address as well – 116.73.133.69 and then let us know so that we can proceed further.
October 14, 2024 at 5:06 PM #236116
olan
ParticipantThat IP isnt blacklisted on our server, please check again.
October 14, 2024 at 5:12 PM #236117
KeymasterUnfortunately we are still not able to access the site. We are getting this https://prnt.sc/tfmMLPtHriKY.
October 14, 2024 at 5:20 PM #236118
olan
ParticipantCan you check now?
October 14, 2024 at 5:30 PM #236119
Keymaster@olan, We are now able to access the login window. Could you please share temporary admin and FTP access to your site with us? Additionally, kindly confirm if we have your permission to deactivate plugins and the theme on your site to further investigate the issue.
Thank you for your cooperation.
October 14, 2024 at 5:33 PM #236120
olan
ParticipantOn the staging site you have now admin rights.
For the ftp, we have to ask the client
October 14, 2024 at 5:40 PM #236122
KeymasterKindly share the admin username and password with us so that we can login on your staging site to check the issue accordingly.
While sharing the access please do mark your reply as private.
October 14, 2024 at 5:45 PM #236124
olan
October 14, 2024 at 6:25 PM #236125
Keymaster@olan, Kindly reset password for the Staging.Gelissen user and share the updated password with us as while resetting the password we are getting this on our end (https://prnt.sc/zseJeYDfr2Gr).
While sharing the access don’t forget to mark your reply as private.
October 14, 2024 at 6:49 PM #236126
olan
October 14, 2024 at 7:18 PM #236127
KeymasterThanks for providing the password. We are now able to login to your staging site. Kindly provide us some time to check the issue on your end and we will get back to you accordingly.
October 15, 2024 at 11:56 AM #236132
KeymasterWe investigated the issue on your site and found that the permalinks were not set correctly, which caused the problem. We have reset the permalinks on your site (see screenshot: https://prnt.sc/l5o5SeyPil8a), and now the settings page is displaying as expected. Please make the same adjustment on your live site and check if the issue is resolved.
If you need further assistance, please feel free to reach out.
October 15, 2024 at 12:29 PM #236133
olan
ParticipantSorry, maybe i’m mistaking but our permalink is already setup like this. See screenshot
Can you tell me which modifications I must make?
October 15, 2024 at 12:47 PM #236135
Keymaster@olan, Please ensure that you have saved the settings after making changes in the permalink section. After that, check the settings for CatalogX, and let us know if the issue persists.
October 15, 2024 at 12:53 PM #236136
olan
ParticipantWe didn’t change anything. Our permalinks on the production site are the same as your screenshot. Maybe we are doing something wrong.
Also we don’t see any settings, see attachement
October 15, 2024 at 1:55 PM #236139
Keymaster@olan, That’s quite unusual, especially since the change in permalink settings resolved the issue on your staging site. Since you’re still encountering the problem on your production site, we kindly request that you create a clone of the current production site and share the access details with us. This will allow us to investigate why the issue persists on your end.
We look forward to receiving the details.
October 15, 2024 at 3:18 PM #236142
olan
October 15, 2024 at 4:20 PM #236143
KeymasterThank you for providing access to the new staging site. Could you also share the FTP access? This will enable our development team to debug the issue on your end and work on a solution as quickly as possible.
Also while sharing the FTP access don’t forget to mark your reply as private.
October 15, 2024 at 4:32 PM #236145
October 15, 2024 at 5:21 PM #236146
olan
ParticipantThanks this version works!!
October 15, 2024 at 5:36 PM #236148
Keymaster@olan, great to hear that. Let us know if you have any further queries.
October 15, 2024 at 6:56 PM #236152
olan
ParticipantHow can I change the text “Send an enquiry” to “Vraag meer informatie”
October 15, 2024 at 7:16 PM #236153
KeymasterYou just need to go to the admin dashboard >> Catalogx >> Settings >> product page builder, from here you can customise the enquiry button as per your requirement.
October 30, 2024 at 1:10 PM #236467
olan
ParticipantThats worked, but with this version I don’t see the required name and phone number provided on the enquiry (see attachement). They are only visible when user is logged in.
October 30, 2024 at 1:29 PM #236470
October 30, 2024 at 2:02 PM #236471
olan
ParticipantI have no permissions for the Google Drive
October 30, 2024 at 2:55 PM #236472
Keymaster@olan, We have updated the permissions. Kindly check now and let us know if you need any further assistance from our end.
October 30, 2024 at 6:06 PM #236479
olan
ParticipantI’ve uploaded the new plugin but the problem still exists.
I’ve noticed that the version is the same as we where using.
October 30, 2024 at 6:27 PM #236496
KeymasterWe’ve reviewed this on our end and couldn’t replicate the issue you described. Could you please share access to your staging site (URL, username, and password) so we can investigate further?
When sharing the access details, please remember to mark your reply as private.
October 30, 2024 at 6:45 PM #236502
olan
October 30, 2024 at 7:06 PM #236503
KeymasterThanks for sharing the access details. Can you please confirm if we can disable plugin/theme on your end to check the flow accordingly.
October 31, 2024 at 10:02 AM #236517
November 6, 2024 at 4:27 PM #236681
olan
November 6, 2024 at 5:01 PM #236684
Keymaster
@Olan, Thank you for bringing this to our attention. We’ve been able to replicate the issue on our end, and I’ve informed our development team. They’re working on a fix, and I’ll keep you updated on the progress.We appreciate your cooperation!
November 13, 2024 at 3:37 PM #236877
olan
ParticipantDo you have any update on the plugin?
November 13, 2024 at 4:30 PM #236879
Keymaster@olan, Thank you for your continued cooperation. As you know, the new version of CatalogX has been in development, and we’ve already implemented several fixes. Our team is currently working on additional improvements and resolving remaining issues, and we’re aiming to release the updated version soon.
If you’d like, please share your email address with us so we can add you to our mailing list. This way, you’ll be notified as soon as the new version is released.
Thank you again for your patience and understanding.
November 14, 2024 at 7:34 PM #236952
Anonymous
InactiveThank you .
November 15, 2024 at 9:58 AM #236960
KeymasterYou are welcome. Let us know if you need any further assistance from our end.
- The topic ‘Enquiry not showing properly’ is closed to new replies.
