WCMp Catalog Enquiry
Tagged: Catalog Enquiry, product variation, short description, translation, wpml
February 8, 2021 at 11:21 AM #115015barbarab123Participant
Hello!
I just ordered and activated the Pro version.
There are 2 problems to solve:
1. We have simple and variable products in our catalog. On the single product page the short description is displayed, for example: Bowl | red (https://borowski-glas.de/produkt/bowl-alligator/). This works well with simple products. But with product variations the short description is hidden, for example: https://borowski-glas.de/produkt/bowl-bird/?attribute_pa_farbe=violett
When I deactivate Catalog Enquiry the short descriptions are displayed correctly.
2. We use WPML for translation of our website. Is it possible to have the enquiry form in two languages (German/English) -
February 8, 2021 at 5:50 PM #115268MVX Support NinjaKeymaster
Thank you for reaching out to us.
Your answers are inline.
When I deactivate Catalog Enquiry the short descriptions are displayed correctly.>> May I know if you have checked marketplace plugin with WooCommerce and standard theme (storefront/twenty). Please deactivate all your plugin, except WooCommerce and WCMp + addon. You can then check the flow. If everything is working fine, in order to detect which plugin is causing conflict- please activate each plugin consecutively and check the flow.
Similarly, for theme conflict- please deactivate the current theme and check with standard WooCommerce theme (storefront/twenty) It is suggested to please perform these tests on your staging website and keep us posted with the outcome.If the issue still exists then please provide us a detailed video of the issue that you are facing so that we can guide you more efficiently.
>> we are compatible with WPML still I will request you to test it on your end. If you face any issue then let us know.
February 22, 2021 at 4:46 PM #116111barbarab123Participant
Hello, the problem with the short descriptions I solved by myself.
But there is still the problem with the translation of the enquiry form. I used WPML string translation but I cannot find the strings.-
March 10, 2021 at 12:49 PM #117293AnonymousInactive
Hey, thanx for sharing this post, i was facing same issue but now it has resolved.
February 23, 2021 at 9:36 PM #116273NerdySupportExpert MoumitaKeymaster
@barbarab123, can you share the missing string file name, so we can check this on our end.
Looking forward to your co-operation regarding the same.
February 24, 2021 at 3:37 PM #116338barbarab123Participant
I found out that I have to scan strings and plugins and choose texts for translation as described here: https://wpml.org/documentation/getting-started-guide/string-translation/finding-strings-that-dont-appear-on-the-string-translation-page/
The translation is done now.I added a captcha to the form. In the free version it was working fine. In Pro version the chaptcha is not showing.
(example: https://borowski-glas.de/produkt/tawny-3/)Please inform me if there is anything to know about your plugin concerning the regulations of the GDPR.
And: I thought I solved the problem with the short descriptions of the product variations but I did not. When I switch to a standard theme it does not help. Deactivating all other plugins also not. Only after deactivating Catalog Enquiry the short description of the variation is displayed.
February 24, 2021 at 6:14 PM #116378barbarab123Participant
In addition to the message above, after clearing the cache I noticed that the translation did not work after all. Now some terms on the English page are still in German. Here are 3 screenshots of the problem.
February 26, 2021 at 6:31 PM #116581WCMp AdminKeymaster
Hi @barbarab123,
Please allow some time to team and we will share our input shortly.
Regards,
March 9, 2021 at 6:50 PM #117243barbarab123Participant
Hello, is there any progress?
Regards -
March 9, 2021 at 7:36 PM #117250NerdySupportExpert MoumitaKeymaster
@barbarab123, the form fields you have added are static custom fields, those are not added by our plugin’s inbuild code. Hence those strings cannot be translated.
Let us know if you have any further queries.
March 9, 2021 at 9:34 PM #117255barbarab123Participant
March 10, 2021 at 12:43 PM #117291NerdySupportExpert MoumitaKeymaster
@barbarab123, Our replies are inline :
– I added a captcha to the form. In the free version it was working fine. In Pro version the chaptcha is not showing.
(example: https://borowski-glas.de/produkt/tawny-3/)>> thanks for reporting this issue. We will fix this in our next update.
– Please inform me if there is anything to know about your plugin concerning the regulations of the GDPR.
>> Using the custom field, you can easily make the form GDPR compliance. However, may I know what particular point are you looking for, so we can help you out accordingly.
– And: I thought I solved the problem with the short descriptions of the product variations but I did not. When I switch to a standard theme it does not help. Deactivating all other plugins also not. Only after deactivating Catalog Enquiry the short description of the variation is displayed.
>> We didn’t face this issue on our end, can you share a temporary admin access so we can check.
While sharing the access, don’t forget to mark the response as private. -
March 10, 2021 at 12:51 PM #117294AnonymousInactive
Hey thanx for sharing your issue, i am facing the same problem, if someone got solution so please share.
thank you.!! -
March 10, 2021 at 3:34 PM #117309barbarab123Participant
Hello, I attached a grafic that explains the problem with the variation description a bit better.
The grafic shows the product “Angelfish” which is a varable product with 3 color variations:
https://borowski-glas.de/produkt/angelfish/?lang=en&attribute_pa_farbe=orange-en -
March 10, 2021 at 3:35 PM #117311barbarab123Participant
Hello, I attached a graphic that explains the problem with the variation description a bit better.
March 10, 2021 at 6:22 PM #117319NerdySupportExpert MoumitaKeymaster
@barbarab123, it seems like theme-specific issue, that is why we needed your site access, to locate the issue.
March 10, 2021 at 7:21 PM #117324barbarab123ParticipantThis reply has been marked as private.
March 11, 2021 at 12:45 PM #117349MVX Support NinjaKeymaster
Thank you for sharing the access details. Kindly confirm us if we can change the theme to default theme in order to find the actual issue.
March 11, 2021 at 3:25 PM #117351barbarab123ParticipantThis reply has been marked as private.
March 12, 2021 at 3:11 PM #117424MVX Support NinjaKeymaster
We have tested with a new variable product and with default theme it is working as you can see here (https://www.loom.com/share/76a73a60bf324251b666453e1ebf668a) with Aveda theme also it is working as you can see here (https://www.loom.com/share/ddbc102b9ba140fca8b5969ca06d2f69)
Kindly check the same at your end and also share a detailed video of the issue that you are facing so that we can guide you more efficiently.
March 12, 2021 at 3:38 PM #117432barbarab123Participant
Thanks for the videos but what you show here is the selection of a certain product variation. This is working. I was referring to the display of the variation description. This is not working with Catalog Enquiry as you can see in the screenshots I sent to you. I have marked the missing variation description in my screenshots in red.
March 12, 2021 at 6:35 PM #117450MVX Support NinjaKeymaster
It seems to be a theme conflict as with default theme (storefront) the product description is visible and with Aveda theme it is not visible as you can see here: https://www.loom.com/share/25164e4c153b426cb0dddf847625208e
So our team needs to debug your site and we might also need help from the theme author.
So, kindly share admin and vendor access (staging site) and FTP access. While sharing the access, please mark the reply as private. -
March 15, 2021 at 5:34 PM #117556barbarab123ParticipantThis reply has been marked as private.
March 15, 2021 at 6:47 PM #117568MVX Support NinjaKeymaster
Our team is looking to it and will update you by tomorrow.
March 16, 2021 at 6:37 PM #117646MVX Support NinjaKeymaster
As this is a theme related issue, hence in order to resolve this we need help from the theme. Kindly ask the theme which hook/filter they use to display these section.Regards,
April 8, 2021 at 5:52 PM #119166barbarab123Participant
Hello, the theme support told me to use this plugin to find what exact hook is being used -> https://wordpress.org/plugins/show-hooks/” target=”_blank” title=”https://wordpress.org/plugins/show-hooks/”>https://wordpress.org/plugins/show-hooks/”>https://wordpress.org/plugins/show-hooks/”>https://wordpress.org/plugins/show-hooks/ It will provide the exact information.
April 9, 2021 at 5:08 PM #119361NerdySupportExpert MoumitaKeymaster
@barbarab123, as much as we want to help you out, we need more help from the theme. It will be difficult for us to study their theme and find the hook.
As they know their own theme, it shouldn’t take them more time. Can’t they share the hook/filter name, otherwise it will be difficult for the support team to give this much time studying a third-party theme.
I hope you understand our end too. -
June 12, 2021 at 3:16 PM #123024MVX Support NinjaKeymaster
Hi, we haven’t heard back from you for a while. We presume this issue has been fixed.
Please open another thread if you need any further help
The topic ‘Catalog Enquiry does not work in Pro Version’ is closed to new replies.
