Contribute, and Reap Abundant Rewards
Custom Fields for product add
WCMp Advanced Frontend Manager
Viewing 1 reply thread
    • #136379
      t.sarsevanidze
      How to create custom fields based on product category ?
    • #136412
      Hi, thanks for reaching out to us.
      Our plugin WC Marketplace follows the default WooCommerce flow for managing category.
      Now, as you need additional fields, then you may use the plugin Advanced Custom Fields (ACF- https://www.advancedcustomfields.com/ ) which is compatible with our add-on Advance Frontend Manager https://multivendorx.com/product/wcmp-frontend-manager/
      But if you are only referring to category section, in that case can you please explain that a bit more. Therefore what flow are you looking for.
The topic ‘Custom Fields for product add’ is closed to new replies.
