WCMp Catalog Enquiry
March 24, 2022 at 3:51 PM #135749andy-8839Participant
Hi
I’m just picking this up as we never managed to resolve this problem. Having had time to check this through, I can see that the issue is not with our theme or bespoke plugins.
I’ve switched to use 2022 theme and disabled most plugins
If you then use the product filter and change the price via the slider that the READ MORE buttons suddenly change to ADD TO BASKET
This shouldn’t happen as they are enquiry only.
Is this an issue between your plugin and the WooCommerce X Product Filter? Please note this is for the free version so I’m not sure if upgrading to the Pro version would fix this or if it exists in both versions.
It would be good to try and get this resolved if possible.
I’ll provide access details in a private reply
Andy
March 24, 2022 at 3:53 PM #135751andy-8839ParticipantThis reply has been marked as private.
March 26, 2022 at 9:30 PM #135808MVX Support NinjaKeymaster
Hi, thanks for getting in touch with us.
Our team is looking into it.
Kindly provide us some time since our team is on weekend. -
March 28, 2022 at 8:24 PM #135848Raju The Cool GuyKeymaster
Hi, we checked this.
By default we use WooCommerce hook/filter, to remove add to the cart.
Now the plugin that you are using has overridden the woocommerce filter and added modifictaion, therefore it is showing add to cart.
Please do ask the plugin author of the product filter to check how we are hiding the add to cart: https://github.com/wcmarketplace/woocommerce-catalog-enquiry/blob/master/classes/class-woocommerce-catalog-enquiry-frontend.php#L242
They need to follow the same for your site.
April 5, 2022 at 4:05 PM #136121andy-8839Participant
Hi Raju
Just to let you know that after some feedback from WooCommerce X Product Filter we were able to fix the issue. It was necessary to disable the Ajax options in the plugin. I’ve included the attachment in case anyone else should have this issue in the future.
Andy
April 5, 2022 at 4:34 PM #136124MVX Support NinjaKeymaster
we are happy to help you
We would love it if you shared your experience by giving us 5/5 review here :
https://wordpress.org/support/plugin/dc-woocommerce-multi-vendor/reviews/#new-post
Seeing glowing reviews from existing customers makes others more comfortable knowing they’ll get the support they need with an issue with our services when arise.
The topic ‘Issue with WooCommerce X product filter’ is closed to new replies.
