Overriding Templates for the Marketplace Membership Module Does Not Work
Viewing 5 reply threads
    • #187454
      Justin Harrison
      Hi Support,
      I’ve run into an issue where no matter what template I try to override from within my theme regarding the Marketplace Membership module, it never works. I have plenty of other templates overriding things in other template paths, but none of the ones work for the Marketplace Membership. I am placing the templates, for example, ‘vendor-subscription.php’ in the path as directed ‘yourtheme/mvx-vendor-membership/vendor-subscription.php’ but it doesn’t work. Can you please confirm that this is the path that should be used within my theme? I feel like there has to be some some kind of bug since overriding the templates for every other part of MultivendorX and MultivendorX Pro have worked and I’m only having problems with this module.
      Thanks in advance!
    • #187458
      Hi @Justin Harrison, sorry to hear that you have faced this issue.
      Can you please share a temporary admin, ftp access so we can check.
      While sharing the access, don’t forget to mark the response as private.
    • #187478
      Justin Harrison
    • #187524
      promita
      Keymaster
      Hi @Justin Harrison, Sorry for the inconvenience. Actually, there was an issue with the overriding instruction. I have added the proper folder structure in your site, please check the modification now.
    • #187535
      Justin Harrison
      Thank you. This has resolved my issue. You can close this ticket.
    • #187577
      Thanks for the update. If you face any issue in future please let us know.
      Also it would be really great if you can give us 5/5 review here: https://wordpress.org/support/plugin/dc-woocommerce-multi-vendor/reviews/#new-post
      This would motivate the team further to do their job more efficiently.
  • The topic ‘Overriding Templates for the Marketplace Membership Module Does Not Work’ is closed to new replies.
