Contribute, and Reap Abundant Rewards!
side menu does not appear on vendor shop page
Viewing 37 reply threads
    • #124230
      erez
      HI
      Due to display issues on vendor shop page I added your code :
      add_filter(‘wcmp_load_default_vendor_store’, ‘__return_true’);
      This resolved the display issue,
      but the side menu does not appear on vendor shop page When I use this code .
      Attaches 2 images:
      1- with the code (no side menu)
      2- Without the code (There is a side menu)
      Is there a code that can add the side menu, or another solution ?
    • #124237
      Hi @Erez , thank you for connecting to us , we will remove cancel order commission from commission list
      in our next update.
    • #124239
      erez
      You are confused with something else in your answer.
      I did not write anything about “cancel order commission” .
      Please read my problem again .
    • #124254
      Hi @Erez , extremely sorry for the inconvenience. By mistake I posted here. Our team is checking this. Kindly provide them some time.
    • #124261
      Hi @Erez , thanks for connecting to us , we have changed our shop page from WCMP 3.5 to give a support to elementor . Before WCMP 3.5 is there side bar in you site ? Our vendor shop page is nothing but a archive page like category page. So if there is side bar in this page then there must be a side bar in shop page also. Kindly check it once and keep us posted. We will help you out accordingly.
    • #124593
      erez
      I do not think I was able to explain the problem correctly .
      On the general store page of the woodmart theme I do not display a side menu .
      Only in the vendor shop page i display a side menu, But I have a lot of display issues there.
      Now, I’m not using Elementor Nor do I have the option to switch to this plugin.
      This transition means rebuilding all the pages on the site and this is not an option .
      I just want the vendor shop page to be displayed properly With the side menu .
      See attached screenshots .
    • #124605
      @erez, can you please create a staging site and share the admin, ftp access so we can check.
      While sharing the access, don’t forget to mark the response as private.
    • #124610
      erez
      I added the staging site Login details In private .
      You can see On the vendor shop page That all the content of the page is to the side.
      If I add the code : add_filter(‘wcmp_load_default_vendor_store’, ‘__return_true’);
      This adjusts the appearance of the page But removes the side menu .
    • #124609
      erez
    • #124615
    • #124626
      erez
      HI , all I want is That the vendor shop page Will display Correctly With the side menu .
      I added the code Because the page does not display well .
      The code addresses the display issues, but But removes the side menu .
      With or without the code, what seems to you to work best . You decide 🙂
    • #124685
    • #124725
      erez
    • #124842
    • #124868
      erez
    • #124901
    • #124903
    • #124949
      erez
      Hi, I’ve opened a support ticket to WoodMart support.
      There is no way to send them an email but I wrote down your address in the ticket .
      Hope they will address the issue soon . I will update you 🙂
    • #124954
      @erez, can you share the forum link, so we can also communicate with them.
    • #125031
      erez
    • #125032
      erez
      I found that if you deactivate this plugin First “Advanced Frontend Manager”
      And only then deactivate “Multivendor Marketplace Solution for WooCommerce – WC Marketplace”
      No error is received .
      I do not know if the problem is in the plugin or WoodMart theme .
      Anyway WoodMart support Still checking .
    • #125096
      erez
      HI
      That’s the answer For the error message from WoodMart support :
      “This error caused a third parties theme.
      Most likely this plugin Multivendor Marketplace Solution for WooCommerce – WC Marketplace is the reason.
      WoodMart theme cannot influence that”
      what am I supposed to do now ?
    • #125109
      erez
      I think the error is related to Advanced Frontend Manager :
      אירעה שגיאה מסוג E_ERROR בשורה 10 בקובץ /var/www/vhosts/nilus.co.il/staging.nilus.co.il/wp-content/plugins/wcmp-frontend_product_manager/classes/integrations/class-wcmp-afm-wholesale.php. הודעת שגיאה: Uncaught Error: Call to undefined function get_wcmp_vendor_settings() in /var/www/vhosts/nilus.co.il/staging.nilus.co.il/wp-content/plugins/wcmp-frontend_product_manager/classes/integrations/class-wcmp-afm-wholesale.php:10 Stack trace: #0 /var/www/vhosts/nilus.co.il/staging.nilus.co.il/wp-content/plugins/wcmp-frontend_product_manager/classes/integrations/class-wcmp-afm-wholesale.php(681): WCMp_Wholesale->__construct() #1 /var/www/vhosts/nilus.co.il/staging.nilus.co.il/wp-content/plugins/wcmp-frontend_product_manager/classes/class-wcmp-afm.php(248): require_once(‘/var/www/vhosts…’) #2 /var/www/vhosts/nilus.co.il/staging.nilus.co.il/wp-content/plugins/wcmp-frontend_product_manager/classes/class-wcmp-afm.php(140): WCMp_AFM->includes() #3 /var/www/vhosts/nilus.co.il/staging.nilus.co.il/wp-content/plugins/wcmp-frontend_product_manager/classes/class-wcmp-afm.php(126): WCMp_AFM->__construct() #4 /var/www/vhosts/nilus.co.il/staging.nilus.co.il/wp-content/plugins/wcmp-frontend_product_manager/wcmp_frontend_product_m
    • #125167
    • #125180
      erez
      1- I checked WCMp was activated . See attached picture
      2- I deleted all code That I added child theme. Same problem .
      3- I checked, getting the same error with the main theme .
    • #125183
      erez
      Until you fix the Error problem in the next version ,
      Can you fix the original problem ? Regarding display issues on vendor shop page .
      What I wrote down at the beginning : (Note that I have already deleted all the codes I added)
      “Due to display issues on vendor shop page I added your code :
      Attaches 2 images:
      2- Without the code (There is a side menu)”
    • #125229
    • #125242
      erez
      Sorry about that, the password will now work
    • #125266
      can you share the log in details so that we can check the issue from your end
    • #125270
      After using this filter, wcmp shop page works like a archive page. Every theme has there own widget and side ber. You can reset all theme settings and widget sections ( It may fix your issue). Please add a vendor location/contact vendor widget to the footer sidebar to debug this issue. Otherwise there is no other issue.
    • #125275
      erez
      reset all theme settings? this IS not a solution .
      If there is no compatibility between your Plugin and woodmart theme
      this whole project is not worth the effort .
      I have no problem paying for it to work properly
      but If you can not fix the problem please update That I could think of another alternative.
    • #125323
      @erez, the issue is coming from your theme. It seems like woodmart doesn’t add a sidebar for the archive page such as category, tag etc. As you can see here : https://staging.nilus.co.il/%D7%A7%D7%98%D7%92%D7%95%D7%A8%D7%99%D7%99%D7%AA-%D7%9E%D7%95%D7%A6%D7%A8/%d7%90%d7%95%d7%a4%d7%a0%d7%aa-%d7%92%d7%91%d7%a8%d7%99%d7%9d/
      Kindly please check with your theme, how can you add a sidebar to this page. If the sidebar is displayed in this page, then it will be added in the vendor shop page also.
    • #125332
      erez
      I believe there is a misunderstanding as to what the problem is . Let me try to clarify .
      As you can see from the screenshot There is a side menu in vendor shop page . (See photo number 1)
      Problems are just display issues (See picture number 2)
    • #125360
      Hi @erez , thanks for connecting with us .
      You can change the display position of the store sidebar from WCMP general settings tab.
      ( screenshot : https://prnt.sc/1f5ht5o )
    • #125361
      erez
      What about the image header ? in is not aligned as the site
    • #125365
      Hi @erez , I have forwarded this to our team .
      Kindly provide them some time to check .
    • #125444
      @erez , we display the banner as per fixed height and width. If you want to change the alignment you may apply your own custom css.
    • #125461
      erez
      Please close this ticket
The topic ‘side menu does not appear on vendor shop page’ is closed to new replies.
