small layout issues
Viewing 7 reply threads
    • #133749
      Criss
      I have a couple small issues on the vendor-list after the latest update
      1) icons not showing
      2) latest product is outside the viewport
      Can you please help fixing it?
    • #133767
      Hi, thank you for getting in touch with us.
      Can you kindly share a video of the issues that you are facing, so that we can assist you further.
    • #133795
      Criss
      🙂 no need to make a video, I explain it in this new screenshot
    • #133808
      It seems like there is some plugin/theme conflict. Just to be sure, disable all the plugins except WooCommerce and WCMp and check again.
      If the issue is still there, switch to some default theme such as twenty twenty and check again.
      Also if the problem still exist kindly share your staging site access.
      Please do keep us posted
    • #133809
      Criss
    • #133830
    • #134388
      Criss
      about issue nr. 2, it’s the same in your demo: products have a margin that pushes them out of the box.
    • #134404
      We tried to recreate this on our end but didn’t face any such issues.( see screenshot- https://prnt.sc/26vh11p ). In our demo that issue is related to the theme, we will communicate with them, so they can fix this in the next update.
      Also, for your site, it seems like a theme issue. Can you please switch to some default theme like Twenty Sixteen and check again.
  • The topic ‘small layout issues’ is closed to new replies.
