October 8, 2021 at 5:04 PM #128812MaxenceTPParticipant
On the seller’s page, if he doesn’t have any product, he is displayed all the reviews of the site (all the products and all the sellers) on his profile. But he has never had a review and he has not yet created a product.
Am I the only one to have this bug?
October 8, 2021 at 5:45 PM #128815MVX Support NinjaKeymaster
Kindly note that in the review settings in admin dashboard you might have enabled “Buyers can rate and review vendor” for which vendors do not need to have products on their store.
Any customer will be able to give review and ratings to your vendor.
Kindly refer to the link below: https://prnt.sc/1vapaou -
October 8, 2021 at 7:37 PM #128824MaxenceTPParticipant
Yes I understand, I did check that box. And I also checked “Review only store users?” and “Product review sync?”.
But I just added this seller and he can’t have had 235 reviews in one minute, that’s the total number of reviews on the site so I think there’s a bug at this level
October 9, 2021 at 2:26 PM #128862MVX Support NinjaKeymaster
We tried to recreate this on our end but didn’t face any such issues. Kindly refer to the link:https://www.loom.com/share/dfda3cbbcd5c4576a9339514f73c7338
Kindly note that the issue you are facing might be due to any of your custom code.
Just to be for sure kindly check by disabling all other plugin except for Woocommerce, WCMp and WCMp add-ons.
Do keep us posted. -
October 9, 2021 at 2:44 PM #128865MaxenceTPParticipant
So I tested in more detail, if I check only :
– Enable Vendor Review
– Review only store users
Everything works without a hitch.However, if in addition to these two settings, I add “Product review sync” it creates several bugs:
– Vendors who don’t have products, have all the reviews of the site
– Sellers who have products have all the reviews of their products in the store but the total of the stars is miscalculated. Here the result should be > 4.5 stars -
October 9, 2021 at 2:51 PM #128869MaxenceTPParticipantThis reply has been marked as private.
October 9, 2021 at 8:18 PM #128892MVX Support NinjaKeymasterThis reply has been marked as private.
October 9, 2021 at 8:36 PM #128894MaxenceTPParticipant
Okay 🙂
Keep me informed -
October 11, 2021 at 9:46 AM #128868MaxenceTPParticipantThis reply has been marked as private.
October 11, 2021 at 3:01 PM #128927MVX Support NinjaKeymasterThis reply has been marked as private.
October 11, 2021 at 5:22 PM #128942MaxenceTPParticipantThis reply has been marked as private.
October 13, 2021 at 8:52 PM #129020NerdySupportExpert MoumitaKeymasterThis reply has been marked as private.
October 14, 2021 at 1:39 AM #129042MaxenceTPParticipant
Ok I’m waiting for your answer 🙂
October 19, 2021 at 5:57 PM #129246Raju The Cool GuyKeymaster
We have recreated this issue on your site and in our end also. We have added a pull request to your GitHub. Here is the updated pull https://github.com/wcmarketplace/dc-woocommerce-multi-vendor/pull/970.
We have also added this pull to your site. Now all working.
Please check and let us know
Thanks -
October 19, 2021 at 8:49 PM #129254MaxenceTPParticipant
Right thank you. Can you release the plugin update that I can update it on my live website ?
October 20, 2021 at 9:46 AM #129270NerdySupportExpert MoumitaKeymaster
@MaxenceTP, it will be difficult to release an update of a plugin for a single fix.
We will soon start working on the next update. We do have plan to release the update by next week.
October 20, 2021 at 5:57 PM #129290MaxenceTPParticipant
Okay, keep me informed
October 22, 2021 at 5:47 PM #129403NerdySupportExpert MoumitaKeymaster
Sure will do @MaxenceTP
October 30, 2021 at 1:41 AM #129870MaxenceTPParticipant
Hello! Is the update now released ?
October 30, 2021 at 12:30 PM #129884MVX Support NinjaKeymaster
will keep you posted as soon as we release the update
October 30, 2021 at 3:11 PM #129886MaxenceTPParticipant
Thank you, I’m waiting for it
October 30, 2021 at 5:53 PM #129896MVX Support NinjaKeymaster
thank you
November 10, 2021 at 10:57 PM #130404MaxenceTPParticipant
Hey, is this fix included in the latest update ?
November 11, 2021 at 4:21 PM #130435MVX Support NinjaKeymaster
This has been fixed in our last update.
November 11, 2021 at 8:26 PM #130458MaxenceTPParticipant
Thank you, it’s now working
The topic ‘Bug seller without products review’ is closed to new replies.
