”Cancel the order”, problem with notification
Viewing 19 reply threads
    • #133684
      wcreartist
      Hi. I´m using your plugin WC MARKETPLACE and I have a problem.
      When a customer makes a purchase, they pass the checkout phase and reach the last step, where they can decide whether to “Pay with a Card” or “Cancel the Order”. If you press “Cancel the order”, the system sends a single notification only to the supplier.
      This same problem is repeated if you press the Pay with Card button and on the bank gateway page, cancel the order.
      I think this is a problem, and I want no notification to be sent.
      Could you help me? Please. Thanks very much. Best Regards
    • #133734
      Hi, thanks for reaching out to us.
      Our team is looking into it.
      Kindly provide us some time.
    • #133893
      wcreartist
      Ok, that you very much. I´m try with this code. I’ll let you know as soon as I try it. Best regards
    • #133912
      Sure.
    • #134098
      wcreartist
      Hi Little, I I have tried with the code but it doesn’t work. The problem is the same. I have implemented your code with Code Snippets, attached screenshot file.
      Could you help me?
      Best Regards
    • #134128
      @wcreartist, can you please create a staging site and share the admin, FTP access so we can check.
      While sharing the access don’t forget to mark the response as private.
    • #134147
      wcreartist
      What do you need?
      Enter WordPress: administrator and password and access via FTP to the web?
      It is right?
    • #134175
      Yes, those are the details we need.
    • #134197
      wcreartist
    • #134216
    • #134223
      wcreartist
    • #134290
    • #134387
      wcreartist
      Thank you very much, now it is working. Could you explain to me what you have done?
      Best regards
    • #134420
      @wcreartist, we removed the mail for canceled order, we will add the same in our next update too.
    • #134447
      wcreartist
    • #134506
    • #134525
      wcreartist
    • #134650
      wcreartist
      Hi, I think you haven’t read my last email. Something new? Best regards
    • #134678
      We have removed previously shared code(reply no #133835) from your theme.
      Hope fully the issue is fixed on you end.
      Kindly check your site and let us know.
      Regards,
    • #134717
      we are happy to help you
      We would love it if you shared your experience by giving us 5/5 review here :
      https://wordpress.org/support/plugin/dc-woocommerce-multi-vendor/reviews/#new-post
      Seeing glowing reviews from existing customers makes others more comfortable knowing they’ll get the support they need with an issue with our services when arise.
  • The topic ‘”Cancel the order”, problem with notification’ is closed to new replies.
