August 12, 2021 at 3:14 AM #126199webmaster.midParticipant
Hello.
My marketplace uses the “%age + fixed per transation” option and WCMp is charging a fixed amount per product (LINE ITEM) in commission, not per transaction (order) as its name purpose.
I’ve been investigating and I got to this old support ticket:
https://multivendorx.com/support-forum/topic/vendor-commission-fixed-per-order/Have you made any changes?
It doesn’t make any sense to have it named as “per transaction”, because it’s not per transaction in fact. It should charge per commission created, that is, per vendor (or suborder, that’s the same).
Hence, the “commission type” should have the following options:
1. %age + fixed per product – It charges per line item – current behavior.
2. %age + fixed per transaction – It charges per commission (vendor)
3. %age + fixed per product unit – This option already exists. -
August 12, 2021 at 11:56 PM #126283NerdySupportExpert MoumitaKeymaster
Hi @webmaster.mid, let us help you out how “%age + fixed per transaction works :
Percentage of the transaction/sale value + a fixed amount per transaction – Product A is priced at $200 and Commission percentage in case of Admin Fees is set to 5% and a Fixed amount of $10 has been set, customer orders 4 Product A. You will receive a fees of $50 [ ( (200*4) * 5/100 ) + 10 ] while vendor receives the rest $750.
let us know if you need any further help.
August 13, 2021 at 6:23 PM #126308webmaster.midParticipant
Hi!
What if I have a Product A and Product B from the same vendor?
Product A – 5% + $10
Product B – 5% + $10Total fixed amount = $20
That way, it’s not per transaction. It’s per product bought.
August 17, 2021 at 6:13 PM #126405NerdySupportExpert MoumitaKeymaster
@webmaster.mid, these commission settings are calculated per vendor.
August 18, 2021 at 8:12 AM #126434webmaster.midParticipant
Hello. You always help me a lot, but at this time, you’re not paying attention to my threads. 🙁
I’m a developer and I’ve analysed the WCMp code in Github.I’ve set in WCMp settings to work with 5% + $ 10 fixed per transaction.
I have a single order with:
Vendor A/Product A
Vendor A/Product BIt’s not being charged only $10 as it was supposed to be (just one vendor). It’s charging $20!!!
Hence, my conclusion is that it’s not charging a fixed amount PER TRANSACTION. It’s charging per PRODUCT.Please, read this old topic here, it’s the same subject:
https://multivendorx.com/support-forum/topic/vendor-commission-fixed-per-order/ -
August 18, 2021 at 8:16 AM #126435webmaster.midParticipant
If you’re a developer, see it here:
https://prnt.sc/1q9ixl8It’s charging PER ITEM, not per transaction. So, considering this:
The “commission type” should have the following options:
August 18, 2021 at 9:06 PM #126491Raju The Cool GuyKeymaster
@webmaster.mid, as per our flow we consider one transaction per order item i.e.%age + fixed per transaction (per vendor per product).
Hence if you purchase two separate products from the same vendor, it will consider as two transactions.However, in our next update, we will add %age + fixed per transaction (per vendor)
You can track the progress of this issue from here : https://github.com/wcmarketplace/dc-woocommerce-multi-vendor/issues/934 -
August 19, 2021 at 12:24 AM #126505webmaster.midParticipant
Great to know that, Raju. I’ve made a quick fix to meet my business rules and I don’t know if it may help you:
I’ve zeroed “commission_fixed” and “commission_val” per item and now I’m calculating it before saving commission (considering that each commission is a suborder).
It worked
August 19, 2021 at 5:42 PM #126517Raju The Cool GuyKeymaster
@webmaster.mid, thanks for taking your time out and helping us with the idea. This will definitely help us.
October 26, 2021 at 6:45 PM #129654MVX Support NinjaKeymaster
Hi, we haven’t heard back from you for a while. We presume this issue has been fixed.
Please open another thread if you need any further help
The topic ‘Commission type: %age + fixed per transation (not per order)’ is closed to new replies.
