Tagged: add product missing, frontend product creation, module issue, Multivendorx pro, Vendor Dashboard
- This topic has 5 replies, 2 voices, and was last updated 11 months, 2 weeks ago by
May 18, 2025 at 3:37 AM #241006
facu.ven3k
ParticipantHello MultiVendorX Team,
I recently purchased MultiVendorX Pro (v1.3.21) and I’m experiencing a critical issue: vendors are unable to add products from their dashboard, as there is no “Add Product” button or any product management options available in the vendor panel.
Here’s what I’ve already tried and confirmed:
✅ Under Settings > Products, all product type and product field options are enabled (see attached Image 1).
✅ Under Modules > Marketplace Types, the “Simple (Downloadable & Virtual)” module is activated (see attached Image 2).
❌ In the vendor dashboard, there is no button to add or manage products (see attached Image 3).
✅ Under Modules > Product Management, I do not see any module named “Frontend Product Editor”, “Product Manager”, or anything that would enable product creation (see attached Image 4).
The only modules visible are “Single Product Multiple Vendor”, “Import Export”, “Store Inventory”, and “Min Max Quantities” — none of which seem to unlock the missing functionality.I’ve also confirmed:
I’m running the latest version (v1.3.21).
My Pro license is active and verified through my account.
There are no hidden buttons like “Enable Advanced Modules” or “Sync Modules” visible anywhere.
Could you please help clarify why the product creation tools are missing from the vendor dashboard, and what I need to do to enable them?
Screenshots are attached for reference.
I would really appreciate a prompt response, as I purchased the product just 3 days ago and I’m already experiencing this issue. I’m looking forward to a quick resolution.
May 18, 2025 at 11:21 AM #241012
KeymasterHi @facu.ven3k, Sorry to hear you’re experiencing an issue. Please navigate to MultiVendorX → Settings → Product Capability and enable the relevant capabilities for your vendors. Once done, check again from the vendor’s side.
If the issue persists, feel free to reach out — we’re always here to help you.
May 19, 2025 at 10:11 PM #241033
facu.ven3k
ParticipantHi, thanks for your response.
Unfortunately, those options have been enabled from the beginning. I’m attaching a screenshot (Image 1) where you can clearly see that the two options are enabled:
✅ Publish Products
✅ Edit Published ProductsHowever, the “Add Product” button still does not appear in the vendor dashboard. I’ve already tried everything mentioned in the documentation and also checked all related modules, but the issue persists.
If you check my previous message, you’ll see that the module is fully activated, and all product types are also enabled — yet the “Add Product” button is still missing from the vendor dashboard.
Looking forward to a solution.
Thanks again.
May 20, 2025 at 10:12 AM #241036
Keymaster@facu.ven3k, Thank you for getting back to us.
It appears that the “Submit Product” capability is currently not enabled on your end, which is why the “Add Product” option isn’t visible on the vendor dashboard.
Kindly enable the “Submit Product” capability, and the option should appear as expected.
If you need any further assistance, feel free to reach out. We’re happy to help!
May 24, 2025 at 2:21 PM #241079
facu.ven3k
ParticipantHi Sangita,
Thank you for your quick response and for identifying the issue.
You’re absolutely right — the “Submit Product” capability was not enabled, which is why the “Add Product” button wasn’t showing up. I’ve now confirmed that everything is working correctly on our end.
Case closed
Thanks again for your assistance. We can move forward with development now.
Best regards,
Facundo -
May 24, 2025 at 3:11 PM #241080
Keymaster@facu.ven3k, We’re glad to hear that your issue has been successfully resolved!
If you need any further assistance in the future, please don’t hesitate to reach out. We’re always here to help.
- The topic ‘Critical Error: Vendors Can’t Add Products – ‘Add Product’ Option Missing’ is closed to new replies.
