Help to complete my custom code
Viewing 21 reply threads
    • #189877
      kevajo
      Hello dear supporters.
      the personalization team asked me to send you my codes to complete the creation of personalized payment for sellers.
      Attached are my source codes.
      I remind you that the custom payment methods I created work correctly in the seller dashboard.
      But the admin already they are not displayed in the payment tab.
      When you select a seller that you want to modify his means of payment from the admin, the means of payment appear normally but the fields to fill in the information do not appear.
      I just want you to tell me how to solve this problem for a single personalized payment, the rest I will do.
    • #189906
      Kevajo, as I can understand you had some previous code. But as those are not compatible with MultiVendorX, hence you need to check which code is not working.
      Our team will guide you with the new hook/filter. But you have to carry on the additional coding with these filters.
      Please understand checking out codes lines by lines, is quite difficult and also not covered under our product support.
    • #189910
      kevajo
      Good evening
      I have everything settled, only the personalized payments from the sellers remain.
    • #190008
      Kevajo, as shared earlier sharing code for custom payment, requires huge amount of coding, which requires you to either hire the developer or create the from your end.
      If you need coding-related help, or hook/filter name do let us know. We will definitely assist you there.
    • #190057
      kevajo
    • #190060
      @kevajo, let us know exactly which code lines you need help with.
      But checking old code snippets is difficult.
    • #190063
      kevajo
    • #190072
      @kevajo, Please understand we didn’t develop this, so have no idea where you need changes and what.
      So, let us know exactly where you need help with, therefore which hook/filter name or coding flow you need?
    • #190076
      kevajo
      I want to display custom payment fields in the admin such as apiemnt by credit card.
      At the seller the fields are displayed.
      I just need to hook or code and where I have to install it
    • #190080
      kevajo
    • #190081
      kevajo
    • #190082
      kevajo
    • #190083
      kevajo
    • #190141
      @kevajo, looking at the code it is quite difficult for us to share why this is not working.
      Our team will share the hook/filter to add menu in the payment tab.
    • #190149
      kevajo
    • #190186
      Hi @kevajo
      We do not have any filter to add menu in the payment tab
      So kindly add below filters for adding a new tab and adding menu under that tab
      mvx_backend_vendor_tab_list
      mvx_vendors_tab_routes
    • #190187
      kevajo
    • #190203
    • #190325
      Hi, you need to use this filter to add additional payment mode under each vendor payment tab mvx_vendor_payment_mode
    • #189879
      kevajo
    • #189880
      kevajo
    • #189911
      kevajo
  • The topic ‘Help to complete my custom code’ is closed to new replies.
