- This topic has 16 replies, 2 voices, and was last updated 1 year, 4 months ago by
December 4, 2024 at 6:11 PM #237547
Alexandre MAUROUARd
ParticipantHello,
We are using your plugin for the Stripe Marketplace integration, and the overall configuration appears to be operational. However, during our tests while placing an order, we encounter the following error message: “You passed an empty string for ‘payment_method’. We assume empty values are an attempt to unset a parameter; however, ‘payment_method’ cannot be unset. You should remove ‘payment_method’ from your request or supply a non-empty value.”
When examining the Ajax request sent upon order submission, I can see that the payment_method parameter is correctly set to mvx-stripe-marketplace (please see the attached screenshot).Could you advise on where we can check for more detailed responses or debug logs regarding this issue?
The site where we are conducting the tests is: https://solook.fr/
Thank you for your assistance.
December 5, 2024 at 10:42 AM #237561
KeymasterHi @Alexandre MAUROUARd, We’re sorry to hear about the issue you’re experiencing.
To check the debug log, you can: Navigate to your admin dashboard: WooCommerce > Status > Logs, or.
Access your server and go to: mvx pro folder > Modules > Stripe Marketplace > Log.
If you need further assistance, please don’t hesitate to reach out.-
December 5, 2024 at 3:38 PM #237565
Alexandre MAUROUARd
ParticipantHello,
We have enabled the logging system, but nothing has been recorded. The same error persists. I believe the issue might be related to the overall order validation form.
On our WordPress page, we currently have the following content:
<!– wp:shortcode –>[woocommerce_checkout]<!– /wp:shortcode –>Is there anything else that needs to be added or configured?
At this point, I’m unable to proceed further without assistance.
Thank you in advance for your help!
December 5, 2024 at 3:47 PM #237566
KeymasterHi @Alexandre MAUROUARd, Could you please create a staging site that replicates your live site exactly? Kindly share the staging site URL along with temporary admin and FTP access so we can investigate the issue further and assist you.
Additionally, a video demonstrating the steps to recreate the issue would be very helpful.
When sharing the access, please remember to mark your reply as private.
December 5, 2024 at 4:34 PM #237568
Alexandre MAUROUARd
December 5, 2024 at 4:50 PM #237570
December 5, 2024 at 5:04 PM #237571
Alexandre MAUROUARd
December 5, 2024 at 6:02 PM #237577
We were able to log in successfully. Could you please confirm if we have your permission to deactivate plugins and the theme on your site to check the flow as needed?
Looking forward to your confirmation.
December 5, 2024 at 6:35 PM #237581
KeymasterWe are looking forward to your confirmation.
December 5, 2024 at 6:54 PM #237585
Alexandre MAUROUARd
ParticipantYes you can. No problem !
December 5, 2024 at 8:48 PM #237587
KeymasterThank you for your confirmation. Kindly provide us some time to check and we will get back to you accordingly.
December 6, 2024 at 10:28 AM #237594
KeymasterHello There, We have checked the flow of placing an order with the Stripe marketplace payment method on your site and in the process we have not faced any such issue as mentioned by you. Kindly check the video here https://www.awesomescreenshot.com/video/34367249?key=b5dff36c67e88149379809245d2b09a4 for the same.
I would suggest you to check carefully again on your end and let us know if you need any further assistance from our end.
December 6, 2024 at 2:28 PM #237598
Alexandre MAUROUARd
ParticipantHello,
This works in your case because the site is completely empty. In our case, we have a child theme and extensions.
The issue is not resolved on our end… -
December 6, 2024 at 4:03 PM #237599
KeymasterHi @Alexandre MAUROUARd, Thank you for getting back to us!
As mentioned earlier, when only the default plugins (MultiVendorX, MultiVendorX Pro, WooCommerce) and a default theme are active, the Stripe Marketplace payment flow works smoothly. However, the issue arises when all your plugins and custom theme are activated, indicating a potential conflict with another plugin or the theme.
To help identify the root cause, please follow these steps:
— Deactivate all plugins except WooCommerce, MultiVendorX, and MultiVendorX Pro.
— Switch to a default theme such as Twenty Twenty-Four or Storefront.
— Test the payment flow again to confirm it works without conflicts.
— Reactivate the other plugins one at a time, testing the payment flow after each activation.Once you identify the conflicting plugin or theme, kindly share its details with us. This will help us investigate the conflict further and provide appropriate assistance.
We appreciate your cooperation and look forward to resolving this for you!
December 6, 2024 at 8:06 PM #237612
Alexandre MAUROUARd
ParticipantWe found the issue. Thank you for your help !
Have a nice day.
Respectfully,
Alexandre MAUROUARD -
December 6, 2024 at 9:40 PM #237613
KeymasterGlad to hear that you have found out the conflicting element.
February 5, 2025 at 10:51 AM #238998
KeymasterWe haven’t heard back from you in a while, so we assume your query has been resolved. We’ll be closing this thread for now.
If you need any further assistance or encounter any issues in the future, please feel free to create a new support ticket—we’ll be happy to help!
- The topic ‘Issue with Payment method’ is closed to new replies.
