March 26, 2022 at 11:36 PM #135812MaxenceTPParticipant
I have a visual problem on the “Questions and answers” tab, especially on the “Load more” button.
It looks like this: https://prnt.sc/XpQLj36bhtII -
March 26, 2022 at 11:37 PM #135813MaxenceTPParticipantThis reply has been marked as private.
March 29, 2022 at 2:59 PM #135869MVX Support NinjaKeymaster
It seems to be plugin/theme conflict in your site.
Kindly share your admin,ftp access so that we can assist you further. -
March 29, 2022 at 3:28 PM #135871MaxenceTPParticipantThis reply has been marked as private.
March 30, 2022 at 11:58 AM #135909MVX Support NinjaKeymasterThis reply has been marked as private.
March 30, 2022 at 11:58 AM #135910MVX Support NinjaKeymasterThis reply has been marked as private.
March 30, 2022 at 5:57 PM #135918MaxenceTPParticipant
I don’t know what you did but you broke my whole site
March 31, 2022 at 12:57 PM #135948MaxenceTPParticipant
I set the theme to default and deactivate all plugins that are not needed. Please test again
March 31, 2022 at 1:04 PM #135950MVX Support NinjaKeymaster
Can you kindly let us know which are the necessary plugin which we need to keep activate so that the site doesn’t break.
Otherwise we can also do a screen recording of the entire process while we test on your site to keep you informed. -
March 31, 2022 at 1:30 PM #135955MaxenceTPParticipant
You just need to leave the “Really Simple SSL” plugin enabled, that’s all.
I have already deactivated all the plugins and set the theme to default so you can test -
March 31, 2022 at 6:00 PM #135958MVX Support NinjaKeymaster
We have recreated this on our end and will fix this soon.
You can track the issue from here- https://github.com/wcmarketplace/dc-woocommerce-multi-vendor/issues/1070#issue-1188003133 -
March 31, 2022 at 7:01 PM #135961MVX Support NinjaKeymaster
We have added the fix. Kindly download it from here- https://github.com/abhirup97/dc-woocommerce-multi-vendor/archive/refs/heads/fix/1070.zip
We will add this in our next update -
April 2, 2022 at 4:02 PM #136024MaxenceTPParticipant
Thank you, I’m waiting for the update to put that on my live website 🙂
April 4, 2022 at 12:05 PM #136056MVX Support NinjaKeymaster
We will keep you posted once we add this in our update.
April 30, 2022 at 10:31 PM #137002MaxenceTPParticipant
Have you been able to progress in one month?
May 6, 2022 at 11:19 AM #137142NerdySupportExpert MoumitaKeymaster
@MaxenceTP, I understand your end, but our current priority is to release the Beta of MVX and the corresponding MVX Pro setup.
Currently, the team is working on a migration from WCMp to MVX. Once that is done, we can release the Beta version, and then only we can work on this thread.
July 16, 2022 at 11:42 PM #140684MaxenceTPParticipant
The update has been released on wordpress since you sent me the fixed plugin ? -
July 26, 2022 at 2:03 PM #140878NerdySupportExpert MoumitaKeymaster
This issue is already fixed in our version 3.8.11.2
The topic ‘Load more button QnA’ is closed to new replies.
