WCMp Catalog Enquiry
May 10, 2021 at 1:01 AM #121362kd5161011Participant
When we configure the enquiry cart for a particular category of product, it still shows on all of the products rather than just select products….We are using WC Catalog Enquiry….
May 10, 2021 at 4:53 PM #121394NerdySupportExpert MoumitaKeymaster
Hi @kd5161011, I presume you are referring to these settings : https://www.awesomescreenshot.com/image/8087184?key=1af899858e6785295a9336c21a414781
In that case, this is exclusion settings. This means you can use this to exclude that product from the inquiry.
If you are referring to some other settings, please do share a scrrenshot so we can help you out.
May 10, 2021 at 7:44 PM #121409kd5161011Participant
Hi @NerdySupportExpert Moumita,
So, we have set some of the Exclusions. They seem to be working however the Add to Cart button now shows up twice on the Excluded product lisitng page. IT seems as if another Add to Cart funcionality is working in the background and messing up the front end pf the product listing. Also, I’m not sure why a Google Pay button is showing up…I don;t have Google Pay enabled.
I can’t capture the problem in one screen shot, so here’s a link to the page:
https://dasstitchhaus.com/product/boho-zentangle-vw-das-bug/If I can get the free version of the WC Catalog Enquiry working reasonably well.. .I do plan to upgrade to the Pro version for the Enquiry Cart functionality. I’m just not sue if this plugin will work well enough with the Divi theme….all I have installed is Divi, Elementor, and WooCommerce…it should work
May 10, 2021 at 8:35 PM #121426NerdySupportExpert MoumitaKeymaster
@kd5161011, it seems theme conflict issue.
Please do create a staging site and share the admin, ftp access of that staging site.While sharing the access, don’t forget to mark the response as private.
May 10, 2021 at 9:42 PM #121430kd5161011ParticipantThis reply has been marked as private.
May 11, 2021 at 5:44 PM #121479NerdySupportExpert MoumitaKeymasterThis reply has been marked as private.
May 11, 2021 at 7:03 PM #121483kd5161011ParticipantThis reply has been marked as private.
May 11, 2021 at 8:07 PM #121494NerdySupportExpert MoumitaKeymasterThis reply has been marked as private.
May 11, 2021 at 8:12 PM #121495NerdySupportExpert MoumitaKeymasterThis reply has been marked as private.
July 13, 2021 at 4:06 PM #124741MVX Support NinjaKeymaster
Hi, we haven’t heard back from you for a while. We presume this issue has been fixed.
Please open another thread if you need any further help
The topic ‘Problem with Divi theme….’ is closed to new replies.
