April 6, 2021 at 7:15 PM #119042francesco rannoParticipant
hi, the users shop page is not working well after the last update, check the attached file.
thanks -
April 6, 2021 at 9:34 PM #119058NerdySupportExpert MoumitaKeymaster
@francesco ranno, thanks for getting in touch with us.
Can you please create a stgaing site and share the admin and FTP access, so we can debug this further.
While sharing the access, don’t forget to mark the response as private.
April 6, 2021 at 10:12 PM #119065francesco rannoParticipantThis reply has been marked as private.
April 7, 2021 at 8:18 AM #119061francesco rannoParticipantThis reply has been marked as private.
April 7, 2021 at 8:32 AM #119094MVX Support NinjaKeymaster
Kindly share STAGING SITE admin and vendor and FTP access as our team need to debug the issue on your site. In order to test and debug the issue further we need to deactivate and activate themes and plugin on your site.
April 7, 2021 at 1:19 PM #119107francesco rannoParticipantThis reply has been marked as private.
April 7, 2021 at 1:58 PM #119113NerdySupportExpert MoumitaKeymaster
Hi @francesco ranno, our team will add a filter, using this you can keep the older version of the Vendor Shop page. But please note, if you use this filter, then you can’t use the elementor to edit the page.
However for now, if you want to proceed with using the filter, then use https://github.com/wcmarketplace/dc-woocommerce-multi-vendor/pull/806 this pull request
So, after downloading the plugin from here – https://github.com/cool-raju/dc-woocommerce-multi-vendor/archive/refs/heads/fix/800.zip, follow these steps :
– Delete the installed WC Marketplace via wp-admin >> plugin
– Unzip the GitHub plugin
– Rename the folder as “dc-woocommerce-multi-vendor” and remove the master tag. Now, zip this folder again.
– Install this plugin on your site.
Please do keep us posted.and then add this below code in your current active theme functions.php file
add_filter('wcmp_load_default_vendor_store', '__return_true');
CopyPlease make all these changes in staging site first and then add the same in live site.
April 7, 2021 at 2:05 PM #119118francesco rannoParticipantThis reply has been marked as private.
April 7, 2021 at 2:22 PM #119133NerdySupportExpert MoumitaKeymasterThis reply has been marked as private.
April 7, 2021 at 2:57 PM #119153francesco rannoParticipantThis reply has been marked as private.
April 7, 2021 at 4:09 PM #119162NerdySupportExpert MoumitaKeymasterThis reply has been marked as private.
June 8, 2021 at 9:52 AM #122743MVX Support NinjaKeymaster
Hi, we haven’t heard back from you for a while. We presume this issue has been fixed.
Please open another thread if you need any further help
The topic ‘problem with store frontend’ is closed to new replies.
