- This topic has 18 replies, 3 voices, and was last updated 3 years ago by
NerdySupportExpert Moumita.
May 15, 2023 at 4:58 PM #192114
Lluis Torns
ParticipantHi!
I am developing a website with your plugin multivendor X version 4.0.7 and MultiVendorX Pro version 1.0.3.
And there is a problem with the auctions. The customer can upload a product but, can’t’ upload and auction.
As an administrator I can’t upload and auction too.
I have modified a little the visual interface of the plugin(so i can’t update the plugin), but I think I didn’t touch anything of the core structure of the plugin.I attach you the error message.
What do you need to resolve this problem?
Thanks!
May 15, 2023 at 9:56 PM #192135
Keymaster@Lluis Torn’s Sorry to hear that you are facing an issue .
But we tried to recreate this on our end but didn’t face any such issue.Can you please share temporary admin access so we can check?
While sharing the access don’t forget to mark the response as private. -
May 16, 2023 at 12:25 PM #192149
Lluis Torns
May 16, 2023 at 11:17 PM #192161
KeymasterOur team will check and get back to you. Kindly provide them with some time.
May 17, 2023 at 12:40 PM #192172
Lluis Torns
May 18, 2023 at 12:20 PM #192233
KeymasterAs per the default flow of WooCommerce the vendor is also a buyer in the marketplace . So if a seller uploads a product he will also be able to purchase that product .Now in your case the flow is not same because of your added customisation .
So kindly create a staging site that should be an exact replica of your live site and share the temporary admin ,FTP access with us . Also kindly share a video how can we recreate the flow on your end . While sharing the access don’t forget to mark your reply as private .
Whenever you are adding customization , do it by template overriding -
May 18, 2023 at 2:32 PM #192245
Lluis Torns
May 18, 2023 at 2:33 PM #192246
Lluis Torns
May 19, 2023 at 9:22 AM #192262
KeymasterHi @Lluis Torns
We have recreated the whole scenario on our end with the exact versions of the plugins. Here the admin can add a new auction product and bid for the product as well . Kindly check this on our site –
url – https://multivendordemo.com/test/test1/wp-admin/
Username – testadmin
Password – ^FOR@yp1pASGI3Z2Ys7GTbyp
You must have added some customization for which the flow is not working on your end . -
May 24, 2023 at 2:09 PM #192410
Lluis Torns
ParticipantHi!
I can’t enter in the test site, maybe the credentials are wrong?
Thanks!
May 24, 2023 at 3:56 PM #192412
KeymasterKindly use these credentials –
site url – https://multivendordemo.comtest//test1/wp-admin
Password – APdo2eD)zg)eDyAX&l0@o2Hn -
May 24, 2023 at 9:34 PM #192433
Lluis Torns
ParticipantToday I have been debugging the code.
I have discovered that there is an incompatibility between your plugin and the WPML translation plugin.
When I deactivate the WPML plugin, I can upload auctions correctly.
By the time I turn it back on I get the following error.
Do you have any idea how to solve it?I attach a screenshots
May 25, 2023 at 6:21 PM #192451
KeymasterHello @Lluis Torns We have already checked WPML with the latest versions of MultiVendorX and MultiVendorX Pro but we are not getting any such issue . Kindly create a staging site and share the site url , temporary admin and ftp access with us . As the earlier shared access is not working anymore .
May 25, 2023 at 6:59 PM #192452
Lluis Torns
May 26, 2023 at 11:05 AM #192468
The issue is not caused because of incompatibility between MultiVendorX and WPML . We have tested the flow keeping MultiVendorX and MultiVendorX Pro deactivated . The error is still coming even when MultiVendorX and MultiVendorX Pro is deactivated. The issue caused because of the incompatibility between the auction plugin and WPML.
You can yourself test it on this site
May 26, 2023 at 12:57 PM #192476
Lluis Torns
ParticipantI see now! There is an incompatibility between the auction plugin and WPML. I understand that since it is not a problem with multivendor x or the PRO, you do not give support, right?
If so, who should I turn to to solve this problem?
However, if you could give me support I would greatly appreciate it. Because I’m very lost at this point.
Thanks!
May 27, 2023 at 2:19 PM #192505
Keymaster@Lluis Torns, I guess you need to contact the Auction plugin author, they would be able to help you out better.
May 29, 2023 at 10:58 AM #192243
Lluis Torns
May 29, 2023 at 10:58 AM #192244
Lluis Torns
May 29, 2023 at 4:04 PM #192599
Lluis Torns
ParticipantPerfect, I’ll contact them.
Thanks!
May 29, 2023 at 9:42 PM #192616
KeymasterWe are closing this thread . If you need help or face issue in future please create a new thread
- The topic ‘Problem with the auctions’ is closed to new replies.
