Theme and Plugin Support
May 15, 2023 at 4:58 PM #192114Lluis TornsParticipant
Hi!
I am developing a website with your plugin multivendor X version 4.0.7 and MultiVendorX Pro version 1.0.3.
And there is a problem with the auctions. The customer can upload a product but, can’t’ upload and auction.
As an administrator I can’t upload and auction too.
I have modified a little the visual interface of the plugin(so i can’t update the plugin), but I think I didn’t touch anything of the core structure of the plugin.I attach you the error message.
What do you need to resolve this problem?
Thanks!
May 15, 2023 at 9:56 PM #192135NerdySupportExpert MoumitaKeymaster
@Lluis Torn’s Sorry to hear that you are facing an issue .
But we tried to recreate this on our end but didn’t face any such issue.Can you please share temporary admin access so we can check?
While sharing the access don’t forget to mark the response as private. -
May 16, 2023 at 12:25 PM #192149Lluis TornsParticipantThis reply has been marked as private.
May 16, 2023 at 11:17 PM #192161NerdySupportExpert MoumitaKeymaster
Our team will check and get back to you. Kindly provide them with some time.
May 17, 2023 at 12:40 PM #192172Lluis TornsParticipantThis reply has been marked as private.
May 18, 2023 at 12:20 PM #192233Sangita Support SquadKeymaster
As per the default flow of WooCommerce the vendor is also a buyer in the marketplace . So if a seller uploads a product he will also be able to purchase that product .Now in your case the flow is not same because of your added customisation .
So kindly create a staging site that should be an exact replica of your live site and share the temporary admin ,FTP access with us . Also kindly share a video how can we recreate the flow on your end . While sharing the access don’t forget to mark your reply as private .
Whenever you are adding customization , do it by template overriding -
May 18, 2023 at 2:32 PM #192245Lluis TornsParticipantThis reply has been marked as private.
May 18, 2023 at 2:33 PM #192246Lluis TornsParticipantThis reply has been marked as private.
May 19, 2023 at 9:22 AM #192262Sangita Support SquadKeymaster
Hi @Lluis Torns
We have recreated the whole scenario on our end with the exact versions of the plugins. Here the admin can add a new auction product and bid for the product as well . Kindly check this on our site –
url – https://multivendordemo.com/test/test1/wp-admin/
Username – testadmin
Password – ^FOR@yp1pASGI3Z2Ys7GTbyp
You must have added some customization for which the flow is not working on your end . -
May 24, 2023 at 2:09 PM #192410Lluis TornsParticipant
Hi!
I can’t enter in the test site, maybe the credentials are wrong?
Thanks!
May 24, 2023 at 3:56 PM #192412Sangita Support SquadKeymaster
Kindly use these credentials –
site url – https://multivendordemo.comtest//test1/wp-admin
Password – APdo2eD)zg)eDyAX&l0@o2Hn -
May 24, 2023 at 9:34 PM #192433Lluis TornsParticipant
Today I have been debugging the code.
I have discovered that there is an incompatibility between your plugin and the WPML translation plugin.
When I deactivate the WPML plugin, I can upload auctions correctly.
By the time I turn it back on I get the following error.
Do you have any idea how to solve it?I attach a screenshots
May 25, 2023 at 6:21 PM #192451Sangita Support SquadKeymaster
Hello @Lluis Torns We have already checked WPML with the latest versions of MultiVendorX and MultiVendorX Pro but we are not getting any such issue . Kindly create a staging site and share the site url , temporary admin and ftp access with us . As the earlier shared access is not working anymore .
May 25, 2023 at 6:59 PM #192452Lluis TornsParticipantThis reply has been marked as private.
May 26, 2023 at 11:05 AM #192468Sangita Support SquadKeymaster
Hi @Lluis Torns
The issue is not caused because of incompatibility between MultiVendorX and WPML . We have tested the flow keeping MultiVendorX and MultiVendorX Pro deactivated . The error is still coming even when MultiVendorX and MultiVendorX Pro is deactivated. The issue caused because of the incompatibility between the auction plugin and WPML.
You can yourself test it on this site
May 26, 2023 at 12:57 PM #192476Lluis TornsParticipant
I see now! There is an incompatibility between the auction plugin and WPML. I understand that since it is not a problem with multivendor x or the PRO, you do not give support, right?
If so, who should I turn to to solve this problem?
However, if you could give me support I would greatly appreciate it. Because I’m very lost at this point.
Thanks!
May 27, 2023 at 2:19 PM #192505NerdySupportExpert MoumitaKeymaster
@Lluis Torns, I guess you need to contact the Auction plugin author, they would be able to help you out better.
May 29, 2023 at 10:58 AM #192243Lluis TornsParticipantThis reply has been marked as private.
May 29, 2023 at 10:58 AM #192244Lluis TornsParticipantThis reply has been marked as private.
May 29, 2023 at 4:04 PM #192599Lluis TornsParticipant
Perfect, I’ll contact them.
Thanks!
May 29, 2023 at 9:42 PM #192616NerdySupportExpert MoumitaKeymaster
We are closing this thread . If you need help or face issue in future please create a new thread
The topic ‘Problem with the auctions’ is closed to new replies.
