- This topic is empty.
January 22, 2022 at 10:04 PM #133503
Kyriakos
ParticipantHello,
At the page /wp-admin/admin.php?page=wcmp-setting-admin&tab=capabilities I have UNchecked the option “If checked, products uploaded by vendors will be directly published without admin approval.”Please check the image: https://pasteboard.co/qILMtpvhkZwv.png
But after the latest update, when ANY vendor uploads a new product, then it is published without admin approval. What am I doing wrong? please advise…
January 24, 2022 at 1:24 PM #133530
MVX Support Ninja
KeymasterHi, thank you for getting in touch with us.
We tried to recreate this on our but didn’t face any such issues.It seems like there is some plugin/theme conflict. Just to be sure, disable all the plugins except WooCommerce and WCMp and check again.
If the issue is still there, switch to some default theme such as twenty sixteen and check again. -
January 24, 2022 at 7:00 PM #133556
Kyriakos
ParticipantWorst reply ever.
I told you that it was working and I have not installed any other new plugin. Did you read that I told you it happened “after the latest update”?
January 24, 2022 at 8:54 PM #133560
MVX Support Ninja
KeymasterSorry for the issue you are facing.
As we are not getting this issue on our end with the updated version
Here is the video- https://www.loom.com/share/502c24e61d03454fbe8eb4c554f6fcd4
But it is happening in your site, we need to confirm if any of your previously installed plugin or theme is causing the issue.Kindly share your admin, ftp access so that we can assist you further.
Also do not forget to mark the response as private while sharing the access. -
January 25, 2022 at 2:09 PM #133580
Kyriakos
ParticipantHello,
I am sure that it works great at your end. WCMP is the best, so we trust and use it the last years. But you can not imagine how disappointing is that when you have a marketplace that works and after an update something happens and one function stop working.Now in order to give you access please tell me about a DAY eg tomorrow, and TIME where I have to make a server snapshot first, and a site announcement if something to do not work properly. And you will check/work without interruptions.
Thank you for your response.
January 25, 2022 at 4:56 PM #133589
Keymaster@Kyriakos, I understand your end.
But in our last update we haven’t modified any Product related capabilities, you can check the same here https://wordpress.org/plugins/dc-woocommerce-multi-vendor/#developers
So we need to check what else has changed in your site. It would be really helpful if you can create a staging site and share the admin, FTP access of that site.
p.s. we are available between 11 am IST to 5 pm IST -
January 26, 2022 at 9:11 PM #133629
Kyriakos
January 26, 2022 at 9:12 PM #133630
Kyriakos
ParticipantPlease check at LIVE site. The staging sites many times work, but LIVE sites not. I need to check that at LIVE site please.
January 27, 2022 at 6:04 PM #133661
MVX Support Ninja
January 27, 2022 at 6:14 PM #133662
Kyriakos
ParticipantA) Which plugin is WCMp exactly? I only have the “Advanced Frontend Manager”.
B) You enabled EVERY plugin? Are you serious?What kind of support is that? Do you support or not? Very disappointed.
January 27, 2022 at 6:58 PM #133672
MVX Support Ninja
Keymaster@Kyriakos, we always ask for a staging site, so we presumed that it was a staging site.
We are extremely sorry for this inconvenience.
Our plugin is Multivendor Marketplace Solution for WooCommerce – WC Marketplace https://prnt.sc/26k5xxuLet us know if you need any further help.
January 27, 2022 at 9:34 PM #133676
Kyriakos
ParticipantDo you support or not? I wrote to you “Please check at LIVE site. The staging sites many times work, but LIVE sites not.”
I only have the “Advanced Frontend Manager” plugin. Is that right or not?
January 27, 2022 at 10:03 PM #133679
MVX Support Ninja
KeymasterWe are extremely sorry for the misunderstanding that occured.
Yes there is our both the plugin WC-Marketplace and Advance Frontend Manager add-on in your site.
January 27, 2022 at 11:02 PM #133680
Kyriakos
ParticipantAs I can see you created 3 test vendor accounts without even enabling them. OK I will make any available update and check alone.
January 28, 2022 at 11:42 AM #133702
MVX Support Ninja
KeymasterWe have created only one test vendor in your site which was shown in the video (see screenshot- https://prnt.sc/26kkkfw ) and the rest vendor accounts was already there in your site.
February 2, 2022 at 11:58 PM #133960
Kyriakos
ParticipantHello,
After some plugin enable actions it fixed. It may need to disable/enable some plugins.Thanks
February 3, 2022 at 10:39 AM #133975
MVX Support Ninja
KeymasterThanks for letting us know.
we are happy to help you
We would love it if you shared your experience by giving us 5/5 review here :
https://wordpress.org/support/plugin/dc-woocommerce-multi-vendor/reviews/#new-post
Seeing glowing reviews from existing customers makes others more comfortable knowing they’ll get the support they need with an issue with our services when arise.
- The topic ‘Products uploaded by vendors are directly published without admin approval’ is closed to new replies.
