May 27, 2021 at 1:58 PM #122260igParticipant
Issue with WCMp 3.7.3 and 3.7.4 versions. With WCMp 3.7.2 everything works fine.
on checkout page sidebar
There are no shipping options available. Please ensure that your address has been entered correctly, or contact us if you need any help.and after placing the order
No shipping method has been selected. Please double check your address, or contact us if you need any help.The same issue happened with both version of AFM 3.2.8 and 3.2.9 (also deactivating WCMp isn’t resolved with AFM 3.2.9)
Woocommerce version 5.3.0.Maybe the problem is checkbox on vendor settings Limit Zone Location?
(our vendors have this checkbox disabled)Regards
May 27, 2021 at 5:35 PM #122267NerdySupportExpert MoumitaKeymaster
@Ivan Gacesa, I am sorry to hear that you have faced this issue.
Can you please create a staging site which will be an exact replica of your live site? Share the admin, vendor and ftp of that staging site.
While sharing the access, please don’t forget to mark the response as private. -
May 27, 2021 at 5:48 PM #122269igParticipantThis reply has been marked as private.
May 28, 2021 at 5:23 PM #122310NerdySupportExpert MoumitaKeymasterThis reply has been marked as private.
May 28, 2021 at 7:04 PM #122313igParticipant
Hi @Moumita.
The option “shipping” from wcmp >> settings >> payment is for transferring the money as described “Transfer shipping charges collected (per product) to the vendor.”
Why do you prohibit vendors to set the shipping option without transferring the money (add shipping cost to the vendor earning)?It works fine on the WCMp version 3.7.2. as I sent, why do you change it?
Changing what some option do between versions and update become the huge issue!
Regards
May 31, 2021 at 3:43 PM #122380Raju The Cool GuyKeymaster
Ivan, the reason we merged the two options, is because the setting “shipping” under WCMp>> general only displayed the shipping tab for the vendor.
However, the shipping configuration by vendor, the payment amount of shipping gets carried out by “shipping” settings of payment.
Now as you didn’t enable the “shipping” option under wcmp >> payment, then how did your vendors add their shipping rate. Can you please guide us here, so we can give you the solution ASAP?
May 31, 2021 at 4:39 PM #122383igParticipant
Abhirub, please check and test all the options before changing the code and how plugin works.
What do you mean ‘general only displayed the shipping tab for the vendor.’? Which tab?
In WCMp General settings there is the option (checkbox) which we use:
Enable vendor shipping – If enabled vendor can configure their shipping on dashboard.What this option do if you remove access for the vendors on the page dashboard/vendor-shipping/?
This option is checked on our site and vendors get the message ‘Sorry you are not authorized for this pages. Please contact with admin.’Once again, Payment settings ‘Transfer shipping charges collected (per product) to the vendor.’ is completely different thing.
How can you just decide the merge this functionality – who can configure shipping and who charges – after a lot of versions of the plugin?
Regards
May 31, 2021 at 7:25 PM #122396Raju The Cool GuyKeymaster
Ivan, several users requested us to merge this option for this two reason :
– If you kept the “shipping” option Under Payment disabled (https://scrgrb.in/wxn) but kept the “shipping” of general section enabled , then vendor can’t do anything. They could only see this option :
‘Sorry you are not authorized for these pages. Please contact with admin.’– But in order to configure the shipping rate and send the shipping money to the vendor, both options for shipping needed to activate.
So, even for our previous version, basically, you had to enable shipping of payment option [Shipping: Transfer shipping charges collected (per product) to the vendor.]
That is why we kept only one shipping option.
Now, can you please explain :
as you are not letting the vendor get shipping rates, then why do you need vendors to add the shipping rates? -
May 31, 2021 at 8:13 PM #122404igParticipant
Abhirub,
‘several users’ can change what plugin do and you didn’t announced this change to all your customers?You left the option in general settings which is not true?
just to show Sorry message to vendors? If you decided something to merge or remove the option.. it’s better to remove the settings option also, to avoid confusion.Our vendors set shipping options, but they don’t earn money from shipping cost (as we wrote in another ticket). These 2 options in WCMp settings (general and payment) are great for selecting a business model, maybe you can change it and make functional as sentences near the checkboxes describe. If ‘several users’ want to avoid vendors to set shipping options they can uncheck this in WCMp general settings.
Thank you
June 1, 2021 at 7:49 PM #122452Raju The Cool GuyKeymaster
Ivan, thanks for explaining this.
I will discuss this with the team. Actually, we are planning the same from our end too.
But, it might take some time to take the shipping configuration flow. -
June 4, 2021 at 2:02 PM #122609igParticipant
The latest update blocks Checkout page and orders! We’ve vendors who set shipping but don’t earn money as we describe many times – Courier services is for shipping and shipping cost.
In the version 3.7.2 there is the option which you decide to remove (don’t know why), please restore it in WCMp General Settings:– Enable Vendor Shipping – If enabled vendor can configure their shipping on dashboard.
and describe in detail (maybe in the manual) the differences between:
– Vendor Earning
– Admin Earning
– Vendor Commission
– Admin Commission
and why do you mix Shipping cost with all of these in transactions and reports.Can you send code that solves this problem, with that we will have a functional site and orders with the latest version 3.7.4. while we wait for you to restore the old option from version 3.7.2?
Regards
June 4, 2021 at 6:46 PM #122631NerdySupportExpert MoumitaKeymaster
@Ivan Gacesa, in our next update we will add a more clear version of shipping.
– One shipping option will let vendor add shipping and calculate shipping cost
– Shipping under payment will only send the vendor their shipping amount
We have the plan to add this in our next update, hopefully within next week.You can track this from here: https://github.com/wcmarketplace/dc-woocommerce-multi-vendor/issues/865
June 16, 2021 at 2:38 PM #123216igParticipant
@Moumita thank you for the new WCMp version 3.7.5, you implemented 2 shipping options and vendor can set shipping on dashboard even they don’t earn money from shipping cost, great.
One small thing, I saw that you removed shipping cost in the WCMp -> Reports -> Sales distribution (in the previous WCMp version it was ok).
In the screenshot you can see, product price is 1000, shipping cost 1000. Vendor commission is 15% which is ok, Admin Net Earning should be 849 or do we need one more column Admin Earning 849? -
June 17, 2021 at 1:46 PM #123288NerdySupportExpert MoumitaKeymaster
Hi, Ivan we will fix this in our update with WCMp Advanced Report.
Our team will share the fix with you.In the mean time, I hope you are satisfied with our assistance and plugin. A 5/5 review here- https://wordpress.org/support/plugin/dc-woocommerce-multi-vendor/reviews/#new-post , would be a great way to share your experience with others.
July 20, 2021 at 3:31 PM #125153
July 20, 2021 at 6:09 PM #125161NerdySupportExpert MoumitaKeymaster
@Ivan Gacesa, the team is currently working on WCMp Vendor Stock alert enhancement. Once that is done, we will work on this.
So hopefully we can release an update on this issue by next week. -
September 18, 2021 at 7:47 PM #127812
September 22, 2021 at 12:32 PM #127968NerdySupportExpert MoumitaKeymaster
@Ivan Gacesa, it will be difficult for us to release a whole update just for one fix. We do have a plan to work on the degradation of the report plugin. In that update, we will release this.
However, for now, I am sharing you a plugin with this fix. Kindly check your mailbox.
September 23, 2021 at 7:21 PM #128059igParticipant
Thank you @Moumita,
I installed the zip which you sent yesterday and still have the same problem (same as screenshot in the previous post).
The price of the product is 1000, shipping cost 1000. Vendor commission is 15% which is ok, Admin Net Earning should be 849 (not 1849 with added shipping as you calculated). Shipping cost in the table is still 0, not 1000 as it should be.
September 28, 2021 at 6:26 PM #128341NerdySupportExpert MoumitaKeymaster
@Ivan Gacesa, can you please share a temporary admin access so we can check.
While sharing the access, don’t forget to mark the response as private. -
October 5, 2021 at 1:36 AM #128620igParticipantThis reply has been marked as private.
October 5, 2021 at 8:36 PM #128658NerdySupportExpert MoumitaKeymasterThis reply has been marked as private.
October 7, 2021 at 7:24 PM #128756igParticipantThis reply has been marked as private.
October 8, 2021 at 9:46 AM #128783NerdySupportExpert MoumitaKeymasterThis reply has been marked as private.
October 13, 2021 at 8:49 PM #129019igParticipantThis reply has been marked as private.
October 13, 2021 at 9:15 PM #129026NerdySupportExpert MoumitaKeymasterThis reply has been marked as private.
October 14, 2021 at 4:41 PM #129056igParticipantThis reply has been marked as private.
October 18, 2021 at 3:03 PM #129018igParticipantThis reply has been marked as private.
The topic ‘Shipping problem on Checkout page with WCMp 3.7.3 and 3.7.4’ is closed to new replies.
