WCMp Advanced Frontend Manager
July 15, 2021 at 1:09 PM #124883admin-8305Participant
Hello!
For some reason I can’t load the “Advanced Report” tab in my seller’s personal account. I checked on your live example, this tab is loaded, but for some reason it takes longer to load all the other tabs. And I have it does not load at all. First, a few minutes like it is loaded, and then pops the error 504.
Technical support for my hosting said:
“Judging by the strays to the database there is a large number of the same type of requests of the form:sendto(5, “n\0\0\0\3SELECT option_value FROM wp_options WHERE option_name = ‘_transient_timeout_wc_product_chi”…, 114, MSG_DONTWAIT, NULL, 0) = 114
poll([{fd=5, events=POLLIN|POLLERR|POLLHUP}], 1, 86400000) = 1 ([{fd=5, revents=POLLIN}])
recvfrom(5, “\1\0\0\1\1R\0\0\2\3def\20u1344753_alltact\nwp_options\nwp_options\foption_value\foption_value\f\10\0\377\377\377\377\374\21\20\0\0\0\5\0\0\3″…, 6459, MSG_DONTWAIT,
NULL, NULL) = 124
sendto(5, “f\0\0\0\3SELECT option_value FROM wp_options WHERE option_name = ‘_transient_wc_product_children_66″…, 106, MSG_DONTWAIT, NULL, 0) = 106
recvfrom(5, “\1\0\0\1\1R\0\0\2\3def\20u1344753_alltact\nwp_options\nwp_options\foption_value\foption_value\f\10\0\377\377\377\377\374\21\20\0\0\0\5\0\0\3″…, 6335, MSG_DONTWAIT,
NULL, NULL) = 192
sendto(5, “\371\0\0\0\3SELECT wp_posts.ID FROM wp_posts WHERE 1=1 AND wp_posts.post_author IN (200475282) AN”…, 253, MSG_DONTWAIT, NULL, 0) = 253
recvfrom(5, “\1\0\0\1\1:\0\0\2\3def\20u1344753_alltact\10wp_posts\10wp_posts\2ID\2ID\f?\0\24\0\0\0\10#B\0\0\0\5\0\0\3\376\0\0\2\0\6\0\0\4\00545240\6\0\0\5\0054516″…, 6143,
MSG_DONTWAIT, NULL, NULL) = 2365
recvfrom(5, “\1\0\0\1\1:\0\0\2\3def\20u1344753_alltact\10wp_posts\10wp_posts\2ID\2ID\f?\0\24\0\0\0\10#B\0\0\0\5\0\0\3\376\0\0\2\0\6\0\0\4\00545240\6\0\0\5\0054516″…, 3778,
MSG_DONTWAIT, NULL, NULL) = 2365How do I make the Advanced Report page load?
July 15, 2021 at 7:21 PM #124918admin-8305Participant
Tried it, but the problem remains
July 15, 2021 at 7:41 PM #124928WCMp AdminKeymasterThis reply has been marked as private.
July 15, 2021 at 7:43 PM #124929admin-8305ParticipantThis reply has been marked as private.
July 15, 2021 at 7:46 PM #124930admin-8305ParticipantThis reply has been marked as private.
July 15, 2021 at 7:56 PM #124932MVX Support NinjaKeymasterThis reply has been marked as private.
July 16, 2021 at 10:06 AM #124956MVX Support NinjaKeymasterThis reply has been marked as private.
July 16, 2021 at 1:09 PM #124959admin-8305ParticipantThis reply has been marked as private.
July 17, 2021 at 12:15 PM #125013admin-8305ParticipantThis reply has been marked as private.
July 17, 2021 at 12:54 PM #125014NerdySupportExpert MoumitaKeymasterThis reply has been marked as private.
July 17, 2021 at 1:33 PM #125015admin-8305ParticipantThis reply has been marked as private.
July 19, 2021 at 7:33 PM #125105NerdySupportExpert MoumitaKeymasterThis reply has been marked as private.
July 20, 2021 at 12:12 PM #125139admin-8305ParticipantThis reply has been marked as private.
July 20, 2021 at 6:47 PM #125174MVX Support NinjaKeymaster
Hello , hope you are doing well .
We will fix this in our next update . -
January 10, 2022 at 2:41 PM #132917MVX Support NinjaKeymaster
This has been fixed in our update.
The forum ‘WCMp Advanced Frontend Manager’ is closed to new topics and replies.
