May 31, 2021 at 3:59 AM #122371Enzo PellecchiaParticipant
I have a problem on supplier page links with WPML, it looks like WPML uses the store name as the link and not the slug.
Even if the translated page exists it becomes unreachable because the url is wrong.Is the problem up to you or to WPML?
May 31, 2021 at 8:53 PM #122411Raju The Cool GuyKeymaster
Hi , we have just given support to add individual data for each and every language. Everything is done by normal WCMp code. Rest of the link recognization and language-based linked check all are done by default wpml. You might have permalink issue.
But as we can see from your WordPress backend screenshot you are currently an Italiano page( maybe Italiano is your default language ). Please switch to English language from WordPress backend header section to check what is the slug name in English. Maybe you have added a different slug for english. Or you have some settings-related issue on wpml. -
June 1, 2021 at 1:25 AM #122412Enzo PellecchiaParticipant
I have verified the names are correct in both languages and if I log in using the direct link it works.
But the WMPL flags just seem to use the store name and not the slug.Could you have reversed the store name with the slug?
June 1, 2021 at 7:26 PM #122448Raju The Cool GuyKeymaster
There is no option to reverse for us. Because as per our default flow we are using slug name in vendor shop page. There is no option for us to give you any custom code. Because this is our existing, Until and unless it customizes by another code. You might have some conflict with the database/ custom code. Please create a new vendor and check.
Thanks -
June 1, 2021 at 11:21 PM #122460Enzo PellecchiaParticipant
Listen to me if I enter the slug value in the store name field.
The urls work fine.I believe you are using the shop name field as a slug.
Can you check the code please.
June 2, 2021 at 8:14 PM #122515Raju The Cool GuyKeymaster
We are using shop name for display shop page name and slug name for vendor permalink. Here is the default flow video — https://www.loom.com/share/383065b942e348b2a5d6024e1c372584
You can also see the code – https://github.com/wcmarketplace/dc-woocommerce-multi-vendor/blob/master/classes/class-wcmp-vendor-details.php#L161
https://github.com/wcmarketplace/dc-woocommerce-multi-vendor/blob/master/classes/query/class-wcmp-vendor-query.php#L242
And many more…
Thanks -
August 2, 2021 at 9:14 AM #125776MVX Support NinjaKeymaster
Hi, we haven’t heard back from you for a while. We presume this issue has been fixed.
Please open another thread if you need any further help
The topic ‘Translate problem with wmpl’ is closed to new replies.
