April 11, 2022 at 12:27 PM #136328farazhussain3292Participant
Vendor can not add variations in product. Value entering field is missing. So can’t add attributes.
April 11, 2022 at 1:16 PM #136330MVX Support NinjaKeymaster
We tried to recreate this on our end but didn’t face any such issues.
Here is the screenshot- https://prnt.sc/z7obLSYPWV-TIt seems like there is some plugin/theme conflict. Just to be sure, disable all the plugins except WooCommerce and WCMp and check again.
If the issue still exists, please switch to some default theme such as Twenty Twenty and check again.
Please do keep us posted so we can help you out. -
April 11, 2022 at 2:30 PM #136332farazhussain3292Participant
I am using wolmart theme & whole site is ready, Now I can’t switch theme. Wolmart is supported with WCMP.
Kindly tell me about any techinal conflict or hook which can I re-check or edit. -
April 11, 2022 at 2:34 PM #136333farazhussain3292ParticipantThis reply has been marked as private.
April 11, 2022 at 2:35 PM #136334farazhussain3292ParticipantThis reply has been marked as private.
April 11, 2022 at 4:31 PM #136338MVX Support NinjaKeymasterThis reply has been marked as private.
April 11, 2022 at 4:59 PM #136339farazhussain3292Participant
Even Dashboard is not rendering any html for input field. Attached the HTML file. Kindly share some hooks or code to rendor it. I can also edit the template if required. Let me know what is missing here? It is bit urgent task.
April 11, 2022 at 6:54 PM #136350MVX Support NinjaKeymasterThis reply has been marked as private.
April 12, 2022 at 10:30 AM #136362farazhussain3292Participant
When we select pre-defined attributes, like color or size then we get this error.
Let me know if I can hide them or make them work. -
April 12, 2022 at 11:11 AM #136364MVX Support NinjaKeymaster
Kindly create a staging site and share your admin,ftp access so that we can assist you further
April 12, 2022 at 11:15 AM #136365farazhussain3292Participant
We don’t have staging & site is live for early-access vendors. So if there is a short way to hide them. Please let me know as we don’t have much time.
Hope you understand. -
April 12, 2022 at 4:36 PM #136375MVX Support NinjaKeymaster
Kindly install WP staging and create a staging site because we need to deactivate plugins and themes in order to fix the issue.
However if you give the permission we can also make these changes along with deactivating the plugins and disabling the theme in your live site to fix the issue. -
April 20, 2022 at 3:55 PM #136631farazhussain3292Participant
It was a Wolmart theme issue & they are resolving it. You can close the ticket. Thanks
April 20, 2022 at 4:13 PM #136633MVX Support NinjaKeymaster
we are happy to help you
We would love it if you shared your experience by giving us 5/5 review here :
https://wordpress.org/support/plugin/dc-woocommerce-multi-vendor/reviews/#new-post
Seeing glowing reviews from existing customers makes others more comfortable knowing they’ll get the support they need with an issue with our services when arise.
The topic ‘Variable Product is not supported for vendor dashboard.’ is closed to new replies.
