WCMp Advanced Frontend Manager
November 16, 2021 at 10:41 AM #130588Sahil ShaikhParticipant
Once an order is placed, only a link is provided to add review only for the vendor – https://snipboard.io/JMFXCD.jpg
After clicking on the link, it diverts us to the storefront page where we are faced with another issue. Instead of showing 5 stars, we are given a choice with 10 stars and these are two different 5 stars – https://snipboard.io/zoPGLF.jpgRegarding the product review we are not provided with any links to add them. I had to manually find the product and find the review section to add it. https://snipboard.io/pvM0wk.jpg
But once I click “Submit” i get the following error – https://snipboard.io/DRdjpg.jpg
November 16, 2021 at 2:02 PM #130627MVX Support NinjaKeymaster
Hi, thank you for getting in touch with us.
We tried to recreate this on our end but didn’t face any such issues.
Kindly refer to the links below:
This is the link when only one/no category was provided for review: :https://www.loom.com/share/4b3648e0b5b546f4aa0365b333595457
This is the link when we provided two category options for reviews: https://www.loom.com/share/278cde1512fe445a85873ce1afa4c33e
It seems like there is some plugin/theme conflict. Just to be sure, disable all the plugins except WooCommerce and WCMp and check again.
November 18, 2021 at 9:33 AM #130740Sahil ShaikhParticipant
Thank you the help.
The vendor review is working.
However, I did not see any mention regarding the Product Review.. Can you please check this part again – Thank you
________________________________________________________________________________________________________________________________Regarding the product review we are not provided with any links to add them. I had to manually find the product and find the review section to add it. https://snipboard.io/pvM0wk.jpg
November 21, 2021 at 9:03 PM #130857Sahil ShaikhParticipant
Can you please reply to my query above!
November 22, 2021 at 2:00 PM #130877MVX Support NinjaKeymaster
We tried to recreate this on our end but didn’t face any such issues, as you can see here https://www.loom.com/share/40398c2582b441a2872ecaaa719f792dNow can you share a video of the issue you are facing.
November 23, 2021 at 2:21 AM #130928Sahil ShaikhParticipant
Thank you for the follow up,
Following screen share shows the error we are facing when we click submit.
https://www.loom.com/share/340d69cb67cb4d1180967a7c12451a9a -
November 23, 2021 at 3:54 PM #130941NerdySupportExpert MoumitaKeymaster
Hi Sahil, thanks for the video.
As we can see this is a product review, which gets carried out by WooCommerce. Anyway, this issue is not coming on our end too.
If the issue still persists then share the admin,ftp access. Also do not forget to mark the response as private while sharing the access.
The topic ‘Vendor or Product Review not working’ is closed to new replies.
