Vendor Order Details Exchanged Currency Problem
Viewing 6 reply threads
    • #195116
      Chris
      Hi support,
      Please instruct me on where can I locate the order item details data for price in vendor order details page as it does not change to my exchanged currency when some user used certain exchanged currency during checkout. https://prnt.sc/sHQ0pNITn_LN
      How do I correct this? I have code snippets to make the value of the exchanged currency calculated for RnB product in various circumstances. But I guess it needs some modification for this part. Seems like its not using wc-meta-item?
    • #195131
      We used $item->get_formatted_meta_data( '' ) function to get item meta of the order.
      Can you please share a complete scenario and detailed video what you actually want. what is ta code, and if you using any plugin to change the currency then share the plugin details.
      Regards,
    • #195159
      Chris
    • #195160
      Chris
    • #195161
      Chris
    • #195207
      Chris, kindly check from admin end what is the amount showing there by default.
      We will display the same data for vendors too.
      Please do share some screenshots, so we can assit you with this.
    • #197248
      Its been long and we have not heard back from you. We presume your query is solved now. We are closing this thread. If you need help or face issue in future please create new support forum topic.
  • The topic ‘Vendor Order Details Exchanged Currency Problem’ is closed to new replies.
