WCMp Advanced Frontend Manager
May 26, 2021 at 4:38 PM #122207DragNfLyParticipant
I have been testing the vendor suspension. I suspended a vendor, then I set his user role to “Rejected Vendor” so he could re-apply.
After the vendor application was approved and activated; – the vendors products no longer appear on the vendor Storefront page.
The products do show up under his “All Products” section but do not show on the Storefront page.
How can I get the vendor products to re-appear on the Vendor Storefront page?
I look forward to hearing from you.
Kind regards,
Dale -
May 26, 2021 at 4:55 PM #122209DragNfLyParticipant
… I have tested this further and the vendor has added another product which was published by admin. This new product appears in the Vendor Storefront.
The storefront message says: Showing all 2 results
…but there is only 1 product displayed (the newly added one)
Event the Category of the product that does not show displays on the storefront but not the product itself?
The product is assigned to the Vendor.
Please help.
May 27, 2021 at 6:41 PM #122273NerdySupportExpert MoumitaKeymaster
@DragNfLy, thanks for explaining the issue, we are able to recreate this on our end. We will fix this in our next update. You can track the progress of this issue here : https://github.com/wcmarketplace/dc-woocommerce-multi-vendor/issues/860
For now, you can follow this to fix this. If you know the products belong to this vendor, then go to wp-admin >> Products. Select the product and use bulk mode option to reassign that product to the vendors.
May 27, 2021 at 6:55 PM #122276DragNfLyParticipant
Hi Moumita,
Thank you for your reply.
I look forward to this fix ; -the method of bulk mode update does not fix the issue though.
After selecting the vendor in bulk edit and updating; – the product still does not appear in the vendor storefront. On the all products page it does however say that the product has been allocated to the vendor. When checking the bulk mode product edit; – The vendor selection is blank and no vendor selected.
Hope this helps.
…and that this could be fixed asap 🙂
Kind regards,
Dale -
May 27, 2021 at 7:03 PM #122278DragNfLyParticipant
…also; – if i edit the product in normal edit mode and click the “Unassign Vendor” button and update; – then all the vendor products disappear from the vendor storefront; – not only the edited product >>> could be another bug.
May 29, 2021 at 1:50 PM #122331NerdySupportExpert MoumitaKeymaster
Dale, this is not an issue on our end as you can see here : https://www.loom.com/share/4549c44bd7ff44d8a04d6dc32cc72a98
So, it seems like your site-specific issue. please test the flow using only woocommerce, WCMp and addons.
May 30, 2021 at 9:14 PM #122367DragNfLyParticipant
OK Moumita, Thanks for the vid. It probably has something to do with the initial issue.
I look forward to the next update so i can resume my testing.
Kind regards,
Dale -
May 31, 2021 at 7:32 PM #122399NerdySupportExpert MoumitaKeymaster
Sure Dale, we will keep you posted.
June 15, 2021 at 1:33 PM #123138DragNfLyParticipant
Hi Moumita,
Thanks for the latest WCMp update this morning.
I can confirm that this issue is now resolved and all Vendor products are displayed on the Vendor Storefront.
The issue of all Vendor products disappearing after ‘Unassigning a Vendor” from a product from the post above in this thread > https://multivendorx.com/support-forum/topic/vendor-products-not-showing-on-storefront/#post-122278
…has also been solved by the latest update.Thank you very much. You can close this ticket.
Kind regards,
Dale -
June 15, 2021 at 5:31 PM #123154MVX Support NinjaKeymaster
thanks for the update !!
June 15, 2021 at 5:31 PM #123156MVX Support NinjaKeymaster
I hope you are satisfied with our assistance and plugin. A 5/5 review here- https://wordpress.org/support/plugin/dc-woocommerce-multi-vendor/reviews/#new-post , would be a great way to share your experience with others.
This motivates us to continue providing the best experience possible and also helps others know how WC-Marketplace can make their life easier.
The topic ‘Vendor Products not showing on Storefront’ is closed to new replies.
