WCMp Vendor Membership
March 25, 2021 at 3:01 AM #118226waqas-4549Participant
One of my the vendor accounts can not add products getting the following error
“No allowed Product types found. Please contact site administrator.”And then when I went to look into the setting which are usually located in the left Bar of WP-admin, I could not locate that…
The registration page, vendor listings and individual store front pages have also been effected!
Following link shows both of the issues:
https://www.loom.com/share/9587bbde7dfa4b809eb3737375265e20 -
March 25, 2021 at 12:59 PM #118247MVX Support NinjaKeymaster
The video is not getting loaded as you can see here https://prnt.sc/10uvjjr
Kindly create another video or explain with the help of screenshot.
March 25, 2021 at 2:23 PM #118261waqas-4549Participant
Attached are the screenshots discussed above!
March 25, 2021 at 2:41 PM #118265MVX Support NinjaKeymaster
May I know if you are looking for vendor type settings?
With updated WCMp membership plugin the vendor type option has been removed and you have to create the membership plan under subscription product type.I will request you to check the membership plan from the product list as you can see here (https://prnt.sc/10uy83d) and see if you have allowed your vendors to add products as you can see here (https://prnt.sc/10uyapo).
Kindly refer to this video link : https://drive.google.com/file/d/17hh_vrgw3qWgHhM7U_O9T0WlCKKMlriM/view?usp=sharing
which will guide you further. -
March 25, 2021 at 3:33 PM #118266NerdySupportExpert MoumitaKeymaster
@waqas-4549, from our last update we are treating each vendor plan as a product type. So, you can access the plan from WP-admin >> Products >> Product Type -> WCMp Subscription.
This video will help you out further: https://www.loom.com/share/7cb6467e77494af6b2514bc06fe8ad19
March 25, 2021 at 11:05 PM #118299waqas-4549Participant
Thank you! Where can I see the updates which were conducted on the latest plugins?
Also, I noticed that the storefront and store listing page layouts have been modified.
I would like to know how to get the map feature on the store listings page as indicated in the screenshot.
And also in the layout of the store fronts are all over the place, as shown in the screen shot the social media links are hidden in some corner and the review and phone number are not even displayed properly.Can you please advice me on how to fix these issues.
Thank you! -
March 26, 2021 at 6:33 PM #118328MVX Support NinjaKeymaster
With google API you can set the map feature as you can see here (https://prnt.sc/10w2rul).
Regarding the other part, in order to see the phone number you have to add it from the vendor storefront then it will be visible. If your vendor have review then it will be visible as you can see here https://prnt.sc/10w3bly
March 26, 2021 at 10:41 PM #118345NerdySupportExpert MoumitaKeymaster
Hi @waqas-4549, our replies are inline :
– Where can I see the updates which were conducted on the latest plugins?
>> You can check the changelog of each addon, as you can see here for membership plugin : https://multivendorx.com/product/wcmp-vendor-membership/#tab-changelog_tab
– Also, I noticed that the storefront and store listing page layouts have been modified.I would like to know how to get the map feature on the store listings page as indicated in the screenshot.
>> We will be adding this in our next update.
You can get this from our github. So, download the the plugin from here – https://github.com/wcmarketplace/dc-woocommerce-multi-vendor/archive/master.zip, follow these steps :
– Delete the installed WC Marketplace via wp-admin >> plugin
– Unzip the GitHub plugin
– Rename the folder as “dc-woocommerce-multi-vendor” and remove the master tag. Now, zip this folder again.
– Install this plugin on your site.
Please do keep us posted.– And also in the layout of the storefronts are all over the place, as shown in the screenshot the social media links are hidden in some corner and the review and phone number are not even displayed
>> I am sorry can you share the page, where we can check the issue properly. -
March 26, 2021 at 10:58 PM #118349waqas-4549Participant
The screenshots you sent are not working…
Can you please attach the screenshots instead of sending as links?
We have already entered the google API, but it is still not showing.
Regarding the second concern about the storefront page layout, I know how to add the phone number – Please look at the screenshot attached, as shown the social media links are in the top corner while the rest of the text is not showing properly. -
March 26, 2021 at 11:03 PM #118351waqas-4549Participant
Thank you Moumita,
Following is the link to our storefronts
https://autostoreqa.com/vendor/autostoreqa/ -
March 27, 2021 at 6:33 PM #118394NerdySupportExpert MoumitaKeymaster
@waqas-4549, I just checked your site, didn’t face any issue as you can see here : https://prnt.sc/10x2cxt
Can you please refresh the page and check again.
March 27, 2021 at 6:45 PM #118395waqas-4549Participant
I can not view the screenshots can you please attach them?
Thank you
March 28, 2021 at 12:08 AM #118406waqas-4549Participant
I just saw the screenshot now, attached is that same screenshot with social media icons highlighted.
Furthermore, the Vendor Registration form has also completely changed, is there a way we can get the old layout and design back as shown in the attached image.
Similarly we would like to get the layout back of the store listing page (store fronts) as well.Thank you,
March 29, 2021 at 6:56 PM #118451MVX Support NinjaKeymaster
Regarding registration form, can you please explain to us with the help of screenshots about what all changes that you are seeing presently and what is the old layout that you are referring to so that we can guide you more efficiently.
Regarding the other part, can you please explain which layout you want back for the store list page? Can you please explain with the help of a screenshot so that we can guide you more efficiently.
Also, will request you to share the admin and vendor access (staging site) and FTP access so that our team can check the same at your end. Also, while sharing the access, please mark the reply as private.
March 30, 2021 at 4:40 PM #118500waqas-4549ParticipantThis reply has been marked as private.
March 30, 2021 at 4:41 PM #118470waqas-4549ParticipantThis reply has been marked as private.
March 30, 2021 at 4:41 PM #118473waqas-4549ParticipantThis reply has been marked as private.
March 30, 2021 at 4:43 PM #118504waqas-4549Participant
Attached the screen shots mentioned in my previous message.
March 30, 2021 at 7:37 PM #118523MVX Support NinjaKeymaster
In our latest version of both WCMp Vendor Membership and our core plugin, we have changed the layout of the membership list page and vendor list page.
For the betterment of the plugin at times we do change the design and flow of the plugin. We mention the same in our changelog too.
Regarding the variable product issue, we have found it at our end and we will fix it in our next update.
March 30, 2021 at 9:08 PM #118528waqas-4549Participant
How can we change the layout of the membership list page and vendor list page?
When is the next update releasing?
March 31, 2021 at 7:59 PM #118589NerdySupportExpert MoumitaKeymaster
@waqas-4549, each page has it’s own template. So you have to override that template and modify this as per your need.
Mat I know which plugin’s update are you looking for?
April 1, 2021 at 10:56 AM #118592waqas-4549Participant
Where can I locate those settings? And how do I bring back my old layouts…
As per my previous replies,
I am sharing a screen share of the vendor registration because when I tried to register as a vendor just a few minutes ago, I found that the account created was for a customer rather than a vendor as shown in the following screen share. This was also working before the update.
https://www.loom.com/share/6dc5507f510f4b99a6f3a83ef01a44e7And, I was trying to add variable products to one of our vendor accounts and could not find the fields to type the price and some important information regarding the product as shown in the following screen share: https://www.loom.com/share/eee43ee6ede54372918b8adbff23224a
April 1, 2021 at 6:33 PM #118651MVX Support NinjaKeymaster
To modify the membership plan page you have to edit the below template
Override this template by copying it to yourtheme/wcmp-vendor-membership/wcmp-vendor-membership_template_vendor_plan.php
CopyTo modify the vendor list page template, Override this template by copying it to your
theme/dc-product-vendor/shortcode/vendor-list.php
CopyRegrading the membership plan issue video that you have shared, Can you please confirm if you have tested it with an existing vendor or with a new user. So that we will test it in the same way on your site.
Regarding the other part, our team has started working on it and it will be fixed by next week.
April 1, 2021 at 8:50 PM #118678waqas-4549Participant
Thank you for the reply,
The membership registration issues happened when I registered with a new user
April 2, 2021 at 12:10 PM #118709MVX Support NinjaKeymaster
Our team need to test the same issue on your site. In order to detect the issue we need to deactivate themes and plugin in your site.
Kindly confirm us if we can test it in the site access shared in this thread.If not then kindly share a admin and vendor access (staging site) where we can test this issue at your end.
While sharing the access, please mark the reply as private. -
April 2, 2021 at 4:57 PM #118742waqas-4549Participant
Yes, you may go ahead test using the site access I shared earlier.
Regards,
Waqas -
April 2, 2021 at 5:57 PM #118747MVX Support NinjaKeymaster
We have tested it at your end and initially the user wcmp1 was created with role as customer then after applying for a membership plan his role changed to vendor as you can see here https://www.loom.com/share/b80369a91e794f958ac8602e37de0027
While testing we have kept only WCMp + WCMp addons + woocommerce plugin activated.
It seems to be some conflict with any 3rd party plugin that you are using. In order to detect which plugin is causing conflict- please activate each plugin consecutively and check the flow.
It is suggested to please perform these tests on your staging website and keep us posted with the outcome. -
June 4, 2021 at 6:13 PM #122619MVX Support NinjaKeymaster
Hi, we haven’t heard back from you for a while. We presume this issue has been fixed.
Please open another thread if you need any further help.
The topic ‘Vendors cant add products & Vendor Membership setting missing!’ is closed to new replies.
