hi i have a problem with cron.
I installed the plugin WP Crontrol, and then changed the launch of the cron
wcmp_spmv_excluded_products_map from “every 5 minutes” to “non-repetitive”. I save the resuoltat, but the changes are not saved and the krona runs again every 5 minutes.
maybe this cron uses some other event?
I do not use this plugin feature. Tell me how can I turn it off?
